  • 43 Votes - 2.98 Average
IDS Module Programming
10-11-2012, 06:11 AM
Post: #19
RE: IDS Module Programming
[quote='dibun' pid='86349' dateline='1349561853']
Try with IDS v80.
[/quotYou meant, you have working cracked IDS 80, and it works with genuine VCM? If so then give me link plz.
Need help regarding pc problems, need any software that is not on net?
PM me freelyKolo
10-11-2012, 06:47 AM
Post: #20
(10-06-2012 07:54 AM)amanalice Wrote:  I had asked it before but didnt get any reply. I had downloaded and installed ids v79 and followed the instructions by ircpolice to crack it. I have genuine VCM and software refuses to connect. Also the patch here (extending time) will give me more time to ork with v79 or it is not for v79? Does any 1 has working IDS with crack? Plz reply me in a bit detail.1087
sounds like the vcm is locked or needs updated code
06-23-2013, 09:51 PM (This post was last modified: 06-23-2013 09:52 PM by wiggyshome.)
Post: #21
hi all
does anyone know if this works on v83!!!!
i have installed a fresh xp sp3 and a fresh copy of IDS v83 but no Module Programming is this file for me or do i need something else
thanx
Wiggyshome
06-23-2013, 10:13 PM
Post: #22
(10-06-2012 03:55 AM)dibun Wrote:  I have a Sony Chip VCM clone and IDS v80 with cal 80. I am new to VCM/IDS. Is there any best practise in module programming? so that I dont corrupt the modules. Which saftey precautions should I take care? Can I backup the current software on the modules?
Last time when I tried to upgrade IDS prompted for a new version for PCM.
hi friend
sony chıp vcm not work modüle programmıng....
only orıgınal or hq vcm ....
 Thanks given by: ibmman , kamaleon
06-24-2013, 08:48 PM
Post: #23
hi all
just an update now programming is working on V83
the problem i had was that it would just freeze on the 1st screen ids initialize after i run this file
so all i did to stop it was reinstall crack for V83 and now all works with programming option
dont know if it was a coincidence or not but all working now
wiggyshome
09-10-2013, 11:36 PM
Post: #24
Ford RE: IDS Module Programming
(09-15-2012 09:52 AM)Patrian Wrote:  Hi,
Use those 2x Tools WITHOUT to Un-Install or to Modify ANY DATE in your PC! Kolo
With Version V79 they are COMPATIBLE! Fing32
NOTE: Those Tools they made by Mr. you_what_are and ALL the Thanks & Credits belongs to HIM! 41 41 41
Good Luck! Fing32
Best Regards! Cheer2
AP
Hello my friend i used on v84 ids and it work perfectly but its only 120 days.. When this time finish, whats goNna ocours?
02-02-2014, 12:01 AM
Post: #25
This extender doesnt work with v86.01a is there any new files for the newer ids?
02-02-2014, 02:01 AM
Post: #26
Good Luck! Fing32
AP
You have to use the application again and you'll have new 120 days aviable
Good luck
 Thanks given by: perotok , latino , kamaleon
07-30-2014, 02:04 PM (This post was last modified: 07-30-2014 02:07 PM by vampirept.)
Post: #27
(09-15-2012 09:37 PM)Drakov Wrote:
(09-15-2012 06:58 PM)ishell Wrote:  Can't download from deposit ,tried many time but no luck
Put file in another location
Thank you
Enjoy
Hi to all:
Some one say in another post that this files have a Virus.
Is this true ?
Please see the post of ollygould
http://mhhauto.com/Thread-IDS-v84-module...-available
  Ford Module Programming Application bu.faisal 4 342 09-17-2017 09:16 AM
Last Post: Synkrotronic
  RCM MODULE PROGRAMMING FORD RANGER Valautos 1 341 04-08-2017 05:53 PM
Last Post: MrPhil
Ford replacing climate module on ford mondeo and IDS ajishcusat 2 433 09-29-2016 01:40 PM
Last Post: ajishcusat
Ford Reparing undetected Ford PCM after low battery hang up while programming with IDS kilog 15 2,930 09-15-2016 12:05 PM
Last Post: cionut
Ford Ford IDS 86.02A/92.03 VCM II Module Reprogramming Issue dworley 18 12,226 06-28-2016 02:35 AM
Last Post: A380
Ford IDS Coded PATS - Last Supported Version? (Key Programming) DanMc85 1 958 06-25-2016 11:57 AM
Last Post: Irony
Ford ids module programming not working Misterwit123 4 911 05-17-2016 11:00 AM
Last Post: Sparky001
Ford No module programming in Ford IDS v86 Galane 4 2,708 03-14-2016 07:25 AM
Last Post: fifii69
Ford IDS V86 module programming problem. AcroFlax 9 5,961 01-26-2015 06:36 PM
Last Post: Rvang1
Ford Ford IDS and Mazda IDS in one XP? audi0004 5 2,975 11-24-2014 06:04 AM
Last Post: [email protected]
