Immo off edc16cp34 audi q7
12-07-2017, 12:45 AM
Audi Immo off edc16cp34 audi q7
Hello Sir please help me immo off for this ecu EDC16CP34 0281011960 audi Q7 I have 2 ecu I try to swap the problem withod succes because hardware is not the same but the reference number is the same thanks advance for your help
Attached File(s)
edc16cp34 0281011960 epr.rar
File Type: .rar
Downloaded: 9 times
12-07-2017, 12:52 AM
RE: Immo off edc16cp34 audi q7
try this
Attached File(s)
EDC16CP34 0281011960 EPR off.rar
File Type: .rar
Downloaded: 5 times
12-07-2017, 01:06 AM
(12-07-2017 12:52 AM)SvenR1 Wrote:  try this
i already try this but without success. always no crank engine
but with old ecu engine crank
12-07-2017, 01:11 AM
you can do by your self for future ....
Attached File(s)
VAG EDC16 immo bypass.rar
File Type: .rar
Downloaded: 18 times
 Thanks given by: kimmy
12-07-2017, 03:03 AM
You ask for immo off, we help and not even thanks? You have more than immo problem, hardware have to be same, only may work when ori flash is am29bd and replacement ecu s29cd.
12-07-2017, 09:23 AM
(12-07-2017 03:03 AM)SvenR1 Wrote:  You ask for immo off, we help and not even thanks? You have more than immo problem, hardware have to be same, only may work when ori flash is am29bd and replacement ecu s29cd.
thanks for bad file!!!!!!!
12-07-2017, 09:39 AM
I think you should tall us full story of what are you doing to this car what ecu's you got how many ecus are on the car and what tools you got to play with vags then maybe You will get better solution than the one you are thinking off...
New!!!Clone of med17.5.21,me17.5.24,med17.5.25,EDC17CP56,EDC17CP64 immo off/immo rebuild on VAG ecu's Modus/Clio/Megane steering column repair/virginising Merc EIS/EZS/ECU/Key generation ...and many more.
 Thanks given by: SvenR1 , Fitia
12-07-2017, 10:00 AM
(12-07-2017 09:39 AM)Keller Wrote:  I think you should tall us full story of what are you doing to this car what ecu's you got how many ecus are on the car and what tools you got to play with vags then maybe You will get better solution than the one you are thinking off...
old ecu was burned and i command new one with same reference 0281011960
If i opened ecu, hardware is different, flash also is not the same (29BD and S29C)
I try to swap with ktag but not possible, i try many immo off but without success
12-08-2017, 08:37 PM
(12-07-2017 10:00 AM)Fitia Wrote:  [quote='Keller' pid='1121068' dateline='1512671981']
someone can help me
Toyota VW CRAFTER 2.5 EDC16CP34 4-4 please immo off heeler11 0 99 11-22-2017 12:32 PM
Last Post: heeler11
  Need full BDM data for AUDI Q7 EDC16CP34 shamnas 4 147 11-20-2017 09:56 PM
Last Post: shamnas
Audi Audi A6 4F 2.7 TDI EDC16CP34 Immo OFF DavidG60 4 138 11-14-2017 11:42 AM
Last Post: DavidG60
Audi Audi A6 DTC OFF 17426 and 19591 edc16cp34 sanica 3 110 11-09-2017 06:52 AM
Last Post: autobirotula
  please immo off edc16cp34 audi q7 robertdiag 2 213 09-10-2017 11:36 AM
Last Post: robertdiag
  Touareg 3.0 V6 TDI CR EDC16CP34 Inmo Off gruiz 2 177 08-16-2017 03:29 AM
Last Post: vision66
Audi full BDM for 0281013080, EDC16CP34, Audi A4 3.0TDI, 8E0907401AL Pali33 2 269 08-02-2017 10:56 PM
Last Post: Pali33
  VW CRAFTER EDC16CP34 IMMO OFF PLEASE teefyg1 7 1,099 08-02-2017 09:23 AM
Last Post: asterixvaovao
  Crafter EDC16cp34 Speed Limit Off mickey001 2 248 06-17-2017 12:30 PM
Last Post: mickey001
  edc16Cp34 Audi A8 Pinout from PLUG joe1953 6 1,164 04-18-2017 02:32 PM
Last Post: joe1953
