  • 1 Votes - 1 Average
Insite 7.6 problem
01-11-2017, 08:02 AM
Insite 7.6 problem
Whats happening is I installed and licensed Insite 7.6.2 SP5 on a new windows 10 laptop. Installed the latest drivers for Inline 6 and Nexiq USb link 2. All went well. When testing the drivers all worked like they should. When i try connecting to ecm it gives code that ''communications between datalink and ecm cannot be established or has been lost'' codes 5023 and 5024. sometimes its one and sometimes the other. Both adapters same result. I can then take another laptop that i always use and connections are perfect on both datalinks. With the windows 10 laptop i tried 3 different trucks and constantly have the same connection to ecm issue. Any input will be appreciated as always.
01-11-2017, 09:21 AM
RE: Insite 7.6 problem
Can anyone help or give any pointers?
01-11-2017, 10:55 AM
Make sure on the bottom of the insite page it shows the name of the adapter you are using. Also the vehicle must have power to port and the key on.
I will attach some info that may be a little much but you should be able to fix your issue.
Were both machines licensed with the same medicine & software?
Cummins Insite
1. Start Program.
2. Click on “File  Connections  Add New Connection”.
3. Click “Next”.
4. Click radio button for “RP1210A” and click “Next”.
5. Select correct device ([DEVICE NAME AND/OR DEVICE NUMBER]), and protocol you want to use, J1708/J1939.
6. Click “Next” and a “Connection Name” screen appears.
7. Click Next and a screen prompts you to indicate whether you want to make this connection active or set up
another connection.
8. Click on “make this connection active”.
9. Click Finish.
Attached File(s)
WhyMyAdapterIsntWorking-01182007.pdf
File Type: .pdf
Downloaded: 31 times
Cummins General Adapter Info.txt
File Type: .txt
Downloaded: 2 times
If my post is helpful, please click on Thanks and Reputation buttons Handshake
 Thanks given by: Starlight
01-11-2017, 10:58 AM (This post was last modified: 01-11-2017 11:26 AM by Nomorenoless.)
(01-11-2017 09:21 AM)Starlight Wrote:  Can anyone help or give any pointers?
Buddy, I recomend yu downgrade Windows to Windows 7, X86
On windows 10 you will have lots of issues.
The issues you are having come from the failure of the communication manager open the procolos, you must downgrade to Windows 7 X86 (32 bits if you want run smooth)
If my comment is offensive, perhaps I was hungry Angry and I needed a Snicker. But if it helps you; I appreciate the reputation. Pc
01-11-2017, 04:36 PM (This post was last modified: 01-11-2017 04:40 PM by Starlight.)
(01-11-2017 10:55 AM)TestProbe Wrote:  Make sure on the bottom of the insite page it shows the name of the adapter you are using. Also the vehicle must have power to port and the key on.
Cummins Insite
1. Start Program.
3. Click “Next”.
another connection.
9. Click Finish.
I did this multiple times with no success. It is always on the ecm side. Does anyone have a link or directions on how to get windows 7 again? Staples Depot doesnt sell it any more, I have asked. Yes, both laptops licensed the same way.
01-11-2017, 04:41 PM
im run mostly win10 now and had no issues, i had this prob with win 8 but not 10
01-11-2017, 04:43 PM
Cummins Insite
1. Start Program.
3. Click “Next”.
another connection.
9. Click Finish.
http://mhhauto.com/Thread-Microsoft-Wind...l-editions
01-12-2017, 01:56 AM
This problem only with insite? Can other program connect to the ecm? Like nexiq et .. or jpro . Try 7.5. Insite. Sounds like a protocol issuse is it on autodetect .. sometimes u have to set it to 1708 or 1939.
01-12-2017, 05:03 AM
I've been using 7.6 on 2 different win 10 laptops for all most a year with out any problems with nexiq usb link on bluetooth. Are you trying to connect wired or wireless?
Also try using the nexiq device tester to see if you have connection between computer and usblink
  2018 Cummins isx insite problem johnamanda3 6 498 06-05-2017 11:06 AM
Last Post: Sdtruck12
  N14 Cummins- Insite problem taraba 8 380 05-12-2017 09:13 AM
AA+john-deere-utility-mat+(7) CUMMINS INSITE BIG PROBLEM DieselSuperStore 5 560 04-21-2017 07:16 AM
Last Post: DieselSuperStore
  PROBLEM INSITE 7.6.0.272 Guevinator 6 326 03-19-2017 02:27 AM
Last Post: E5459388377012
  Had a problem win Insite 7.6.2.240 SP5 today IROC 10 725 01-17-2017 05:12 AM
Last Post: IROC
  problem insite 7.6.0.272 Guevinator 14 768 01-13-2017 07:25 AM
Last Post: Ryandraco
  "INSITE could not start a critical INSITE service" Offroadnt 7 646 12-02-2016 10:24 AM
Last Post: strats78
  Insite 7.6 Problem mjisaac 5 482 11-11-2016 01:15 PM
Last Post: Graglor
  Insite 8.1.4 calibrations & Insite 7.6.2.240 SP5 fang88 10 2,270 10-17-2016 08:49 AM
Last Post: smokn stacks
  Cummins Insite Problem solarant 22 3,716 09-12-2016 06:22 PM
Last Post: Nm86
