  • 5 Votes - 3 Average
Iq limiter
08-23-2017, 11:02 AM
Audi Iq limiter
Hi, can someone disable iq limitation, now it's 50,8 mg
Audi a4 2.5 tdi AKE 180 PS.
Attached File(s)
AKE.zip
File Type: .zip
Downloaded: 6 times
08-23-2017, 11:05 AM
RE: Iq limiter
(08-23-2017 11:02 AM)remi87 Wrote:  Hi, can someone disable iq limitation, now it's 50,8 mg
it will be always 50mg it is limited by the pump.You need bigger injectors
 Thanks given by: vision66
08-23-2017, 11:14 AM
RE: Iq limiter
"can someone disable iq limitation, now it's 50,8 mg"
good joke WinkWinkWink41
Did you see duration maps in your file ?
08-23-2017, 11:20 AM
RE: Iq limiter
what do you do man what !
" WinOLS (10580.ols (limiter off ) - 360406).rar" WTF
This is EDC15VM+ ECU with VP44 pump ! Do you know what does mean ha ?
In your dreams you can do limiter off, you can set gear limter higher but duration is on the pump electric ok . WHAT DO YOU DO MAN ha , you open your mouth then tell what you do ?
 Thanks given by: lsdlsd88 , loki954
08-23-2017, 09:09 PM
RE: Iq limiter
(08-23-2017 11:14 AM)vision66 Wrote:  "can someone disable iq limitation, now it's 50,8 mg"
the guy spams everywhere, in other place on 1.8t i ask for hard cut limiter he give me file with vmax off he said this is the solution Smile
i have the same car, put bigger injectors and all will be smokie Big Grin Drive
08-23-2017, 09:10 PM
RE: Iq limiter
its not limited by pump...just need find all limiters in flash there are aprox 10 of them
READ THE RULES NO LIVE LINKS AND EMAIL ADDRESS
08-24-2017, 01:42 AM
RE: Iq limiter
(08-23-2017 09:10 PM)ludbe Wrote:  its not limited by pump...just need find all limiters in flash there are aprox 10 of them
another clownFing20Fing20Fing20
 Thanks given by: loki954
08-24-2017, 07:51 AM
RE: Iq limiter
vp44 limit the fuel to 50mg you can "ask" from the ecu 2000mg you can remove all the limiters but the VP44 will deliver ONLY 50mg MAX Fing32
08-24-2017, 09:31 AM
RE: Iq limiter
(08-24-2017 07:51 AM)loki954 Wrote:  vp44 limit the fuel to 50mg you can "ask" from the ecu 2000mg you can remove all the limiters but the VP44 will deliver ONLY 50mg MAX Fing32
And I bet you are wrong, lets make a try.
You make a log of the quantity valve with all limiters removed, that you know.
Good would be AKE, because I have one here and can post mine log then for comparement.
And You´ll see a big difference then.
  IVECO SPEED LIMITER OFF bogmar 3 103 Yesterday 03:50 AM
Last Post: bogmar
BMW Siemens MSS50 Rev Limiter ikamac 4 84 09-15-2017 01:30 PM
Last Post: ikamac
  Free Popcorn Rev Limiter For forum Members szejkoos 164 26,212 09-15-2017 04:17 AM
Last Post: noslen
BMW Launch Control / Pop Corn Limiter needed lucky0382 2 236 09-12-2017 04:12 AM
Last Post: asperformacne06
  Navara 2.3 dCi SID310 Vmax Speed Limiter Alekscccc 0 121 08-30-2017 10:01 PM
Last Post: Alekscccc
  Honda civic ignition cut limiter athlonxp 4 171 08-23-2017 09:08 AM
Last Post: athlonxp
  Rev limiter popcorn edc16c2 mansens198803 7 317 08-22-2017 01:27 PM
Last Post: jolidj
VW 2.0 TDI Speed Limiter remove mgor 2 199 08-17-2017 03:43 AM
Last Post: mgor
Mercedes Benz disabling the speed limiter Mercedes w212 E400 starica69 1 204 08-15-2017 12:16 PM
Last Post: teobolo
Vauxhall corsa d 1.3cdti speed limiter removal glynm 3 188 08-13-2017 04:44 AM
Last Post: lsdlsd88
