  • 45 Votes - 2.87 Average
Lancia THESIS / LYBRA Connect Siemens update and new maps
12-04-2011, 03:52 AM (This post was last modified: 12-04-2011 03:53 AM by gacopl.)
Lancia Lancia THESIS / LYBRA Connect Siemens update and new maps
Hello I found
The latest setup/software cd for lancia thesis /lybra g3 connect systems, along with updated maps 2010-2011.
It is working perfectly!
Download and burn with IMGBURN
Go to setup change language to german then back to english and your connect will get updated. To see what version you have click and hold main button for 10 seconds
http://gpsunderground.com/forum/opel/774...stems.html
Rgrds
 Thanks given by: armpower
12-05-2011, 03:29 PM
RE: Lancia THESIS / LYBRA Connect Siemens update and new maps
Wonderful! but... my connect is damage cd doesn't work so what solution I have??
Second question to YouSmile
My Panel in Lancia Thesis with navi and air-control doesn't work.
So I buy other but the same problem - nothing working -
Should I use examitor and adapt or something? If I don't, other panel's will newer work??
THX
Mula
12-07-2011, 02:14 PM
Have You fix the problem?
01-05-2012, 12:33 PM
as far as i know when you exchange connect you need to do a can proxy alignment otherwise the stuff wont work, regarding cd, it helped me to clean the laser in connect with simple isopropyl alcohol
Lancia Need file ori MJD8F2.I2 51872449 Lancia Musa dvdpgn 1 172 05-30-2017 11:11 AM
Last Post: sazimam
  throttle body compatible for Lancia lybra 2004 help HIGH TECH AUTO 0 135 05-23-2017 10:49 PM
Last Post: HIGH TECH AUTO
Lancia Lancia Lybra Remote Code docev 0 126 05-16-2017 03:50 AM
Last Post: docev
Fiat LANCIA ECU MAGNETI MARELLI MJD 6JF.Y1 IMMO OFF Tethirim 0 174 03-19-2017 11:11 AM
Last Post: Tethirim
  Lancia Phedra 2003 Sliding Door szejkoos 1 399 09-29-2016 10:44 AM
Last Post: arik
Fiat Lancia Thesis wiring Artifact 0 495 07-09-2016 06:33 AM
Last Post: Artifact
Lancia LANCIA Y lights problem Digidiagnosis 2 565 07-04-2016 08:39 AM
Last Post: Digidiagnosis
Lancia Dpf off Lancia Musa ninolino 2 1,167 02-06-2015 12:57 PM
Last Post: beytus61
Lancia original file mapp lancia delta 1.6 mjtd kazzonex 0 953 06-20-2014 09:13 PM
Last Post: kazzonex
AA+MHH City don't active on Lancia Musa 2007 mimmo258 3 2,106 11-16-2011 06:13 AM
Last Post: dopsleutel13
