  • 53 Votes - 2.79 Average
MB DAS - Xentry 03.2013 Information + Solution
04-29-2013, 10:14 PM
Post: #91
RE: MB DAS - Xentry 03.2013 Information + Solution
Greetings all
The previous licence start Was Starting On Oct, 28, 2012 and I have Modified It To Be In The Same Date Of The installation.
Regards
05-01-2013, 03:03 AM
Post: #92
I upgraded it from 01/13 to 03/13, used updated setup.inx, all went smooth with no errors on Dell D620.
But when the update finished and the laptop rebooted, Xentry shortcut disappeared and it was no longer on the desktop or on the Programs in the Start button.
It could be manually started from F:\Programme\Xentry\bin\start_Xentry.exe
But when it is started, it shows the same version as prior to update, which is 12.0.5.0, DVD: 01/2013
Meanwhile DAS has been upgraded to 03/2013 (2013-02-14) and starts fine.
WIS-ASRA can not be started anymore, says 'Unable to launch the application'.
EPC says the same 'Unable to launch the application'.
I selected only Russian language during installation.
What did I do wrong about the update?
05-01-2013, 03:06 AM
Post: #93
(05-01-2013 03:03 AM)silaznaniya Wrote:  I upgraded it from 01/13 to 03/13, used updated setup.inx, all went smooth with no errors on Dell D620.
Reinstall Xentry 03.2013
remove WIS and EPC shortcuts from desktop and star menu, make sure of EWA keys and run WIS and EPC from EWA main index first and next make new shortcuts
good luck
ORIGINAL Xentry Connect and Bosch Xentry VCI License + Hardware
Remote Installation for 12.2017 Benz, Vediamo, DTS Monaco 8.12.016 and BMW
[Image: giphy.gif]
 Thanks given by: webmaster , Rocinante , ParisCY , ToMiBoY
05-01-2013, 03:48 AM
Post: #94
good luck
I tried to reinstall it again, shortcut did not appear on the desktop.
I then run Starshell. Xentry icon was there with the exclamation sign. When I click on it, it says that the application is not installed at the moment.
05-01-2013, 04:56 AM
Post: #95
start fresh installation from 11.2012
[Image: giphy.gif]
 Thanks given by: Rocinante , ToMiBoY
05-02-2013, 01:53 AM
Post: #96
Good day
Gents.
How to install WIN and starfinder on Das 2013!>> Thanks in advance
05-02-2013, 04:10 AM
Post: #97
WIS? and starfinder are installed the way they have always been installed..
 Thanks given by: webmaster , ToMiBoY
05-02-2013, 09:00 AM
Post: #98
Great,
the advise those ways
05-09-2013, 11:18 PM
Post: #99
One question from my side:
I am using a clone C3 and managed to update the software to version 03.2013.
I also applied "FULL BIN FIXED Folder ONLY For PartD (C3) Mux For DAS 3.2013"
Now in the release notes from Mercedes that Patrian posted it states that the C3 will be locked with this version....
Does this locking happens with only Xentry or Das or both?
And does the "Full BIN Fixed" makes sure the device doesnt get locked only in DAS or both in DAS and Xentry?
Mercedes Benz Beginner Xentry Das mvdgragt 3 164 05-21-2018 07:26 AM
Last Post: mvdgragt
Mercedes Benz Problem with DAS / Xentry after HDD clone dominik.b2325 25 10,628 05-17-2018 10:41 PM
Last Post: lukzlo22
Mercedes Benz MB W220 S63 AMG 2001 AT 722.636 stolen control unit (egs module) of AT-solution? santakruz 0 173 05-14-2018 02:16 PM
Last Post: santakruz
Mercedes Benz Xentry startkey invalid for xentry developer V1.1.0 benz001 36 16,727 05-11-2018 11:42 PM
Last Post: omega1
Mercedes Benz [Solution] Xentry Diagnostics OpenShell 32 Bit Installer (12.2017) Fouad 31 20,153 05-08-2018 04:08 AM
Last Post: Fouad
