  • 1 Votes - 3 Average
MK 2 ford focus immobiliser fault
06-19-2017, 09:15 AM
Ford MK 2 ford focus immobiliser fault
2006 focus intermittent non start. only code is in dash for immo blocked start its had a few dash's and still the same the resistance on the can lines are good at 60 ohms. connectors checked and ok in passenger foot well.
06-19-2017, 09:18 AM
What dtc you have ?
Tunefiles,Remapping,Egr/Dpf/Lambda,Flaps
Skype:Mazolla77
http://auto-revolution.co.uk
06-19-2017, 09:22 AM
RE: MK 2 ford focus immobiliser fault
(06-19-2017 09:18 AM)mazolla Wrote:  What dtc you have ?
the usual u1900
the other code I cant remember but was a can bus code and start blocked by immobiliser car still cranks and red immo light on dash turns off.if the car is left for 5-10 mins it will start
06-19-2017, 10:19 AM
"U" codes are only communication errors between modules
Try to delate all keys and programm it with ids
Skype:Mazolla77
06-19-2017, 10:22 AM
Hi.I think dashboard problem.
https://www.youtube.com/watch?v=H0uQgvrp1xg
06-19-2017, 10:31 AM
i think is the usual solder joints in the dash,resolder and it will be ok.
06-19-2017, 10:33 AM
Check all wiring in and around engine fuse box for corrosion etc .
Check body module for water ingress under glovebox .
Update PCM with later calibration , specific file enhancements were made for PATS weakness on certain vehicles
06-19-2017, 12:06 PM
Definitely dash fault. Open up and solder main plug joints. Done many of these
06-19-2017, 12:28 PM
iv resoldered one dash and its had another two? iv recoded the key when I matched the new donor dash. I will check the fuse box.
the dash has a message saying steering assist isn't working but its mechanical steering pump
Ford Ford Focus 1.6 16v 2007 dash mileage gone crazy mehhrib 5 151 08-17-2017 09:36 PM
Last Post: mehhrib
  p0149 fault code ford focus Kakabasa 11 204 08-14-2017 01:05 PM
Last Post: Colin C
Ford Ford Focus 1.8 TDDI need change FIP fluorescent 5 141 08-11-2017 11:44 AM
Last Post: fraze
  Ford Focus 3 TCM calibration need help Ramis 1 180 07-21-2017 11:00 AM
Last Post: Ramis
  Ford Focus 1,8 TDCI 115 PS P1211 and P0251 please help rosi1000rr 2 209 07-02-2017 08:47 PM
Last Post: Dzltec
  Ford Focus TDCI 1.8 F9DA injector coding via CDP+ euromod 3 1,049 05-12-2017 08:21 PM
Last Post: geneluauto
Ford ford focus ecu change shasse 5 282 04-27-2017 03:23 AM
Last Post: mazolla
Ford Ford Focus radio power up out of car lagri 1 351 04-23-2017 12:05 PM
Last Post: lagri
Ford Ford Focus 1.6 tdci, 95Hp Daku 2 382 04-18-2017 03:49 PM
Last Post: djnonow
Ford psg5 ford focus tekn95 17 549 04-18-2017 03:31 AM
Last Post: tekn95
2 Guest(s)
