  • 1 Votes - 4 Average
Mercedes W129 error ABS
01-11-2017, 12:26 PM
Hello everyone, have if someone has information or know something else. I have a Mercedes W129 of the year 91.
I lit the ABS light and traction control. The engine has no power. In the old connector, not the round, but the previous one, in pin 10 with lights I got the code 29.
For car of 91 I do not get that code, but from 94 if this fault comes out as a lateral acceleration sensor. But this car does not carry, that was for stability control.
Did anyone touch any of these?
a greeting
01-11-2017, 10:13 PM
RE: Mercedes W129 error ABS
ABS at W129 1990-1993 year not diagnosed,look Star-Finder
01-12-2017, 09:29 PM
Hi, thanks for your reply, on the right front of the engine hood, the other side of the plate that keeps ECU abs, ecu motor .... there is a plugged connector. Pin number 10 is for analog diagnosis by ABS / ASR blinking. This gives code 29. Check with an outline all the feeds to the ECU, the relay with 2 fuses above is also OK. In Mercedes they told me that car is in the book nothing digital, but it is so old that they no longer have that book where all the information is Sad
So ask if anyone knows anything about this.
greetings
Thank you.
  mercedes 221 abs problem shmuk 5 202 12-03-2016 01:16 AM
Last Post: shmuk
Mercedes Benz Mercedes 2001 w163 ABS ESP Problem vladu 9 1,092 09-25-2016 03:09 AM
Last Post: battistaci
  Need Mercedes W129 instrument cluster dump ljbp 0 234 08-08-2016 06:32 AM
Last Post: ljbp
Mercedes Benz Mercedes ABS fault baakos 0 310 05-14-2016 02:44 AM
Last Post: baakos
Mercedes Benz !Solved! Mercedes ABS - diode identification valentino_val 3 705 01-24-2016 01:27 PM
Last Post: valentino_val
Citroen galletto write flash sid803a : ERROR SK1, Error SilentKey ?? haydent 3 1,305 11-20-2015 01:36 PM
Last Post: haydent
  fiat ducato abs pump error code disabled in ecu? kcity 3 750 06-26-2015 11:45 AM
Last Post: kcity
Mercedes Benz Mercedes Benz W203 EIS dump error (Hash error) Hamzadaw2000 2 1,284 12-22-2014 01:56 PM
Last Post: Macawa
  Golf 4 1.9tdi 18057 error. DATA BUS MISSING MESSAGE FROM ABS Pro.chiptuning 2 1,792 06-19-2014 10:37 PM
Last Post: Pro.chiptuning
2 Guest(s)
