Mini Cooper 2009 Engine Stall During Driving
06-14-2018, 03:55 PM
Car stall during drive, scan the vehicle no errors.
Starter crank no problem, car does not start at all, there is fuel pressure, there is injector pulse and there is visible spark on spark plug,compression 180 Psi on all cylinders
any one has similar problem ?
06-14-2018, 03:58 PM
RE: Mini Cooper 2009 Engine Stall During Driving
Do you have engine start signal in live data?
Please don't forget rep + thanks buttons below. It is free when you push them. Blush
 Thanks given by: koziolek , KriyenKPp
06-14-2018, 05:09 PM (This post was last modified: 06-14-2018 06:07 PM by MegaCar.)
Mini RE: Mini Cooper 2009 Engine Stall During Driving
(06-14-2018 03:55 PM)koziolek Wrote:  Car stall during drive, scan the vehicle no errors.
Sorry. Try new Coils and plugs, may be not have enough voltage even you can see visible spark.
Hope this help
Drive Press the Thanks and + If I really Help You.Kolo
 Thanks given by: koziolek , diagnostix , KriyenKPp
06-14-2018, 05:52 PM
How do you suggest he checks fuel pressure under load when the car will not start at all?
 Thanks given by: koziolek , MegaCar
06-14-2018, 08:13 PM
Spark plugs are dry or wet after starting? Fuel type is correct? If all previous aspects are good, check timing.
 Thanks given by: koziolek , diagnostix , Bibobabo , KriyenKPp
  BMW F02 740i 2009 Problem after replacing ECU engin mixmaker 4 1,249 Yesterday 02:55 AM
Last Post: mixmaker
BMW 2009 E90 320d key locked in AfXv237 0 920 08-06-2018 06:43 AM
Last Post: AfXv237
Mini Mini Cooper 1.6 2007 Serious problems??? 4life211 4 1,187 07-31-2018 04:32 PM
Last Post: diagnostix
  2007 MINI DME replacement need info koziolek 4 1,749 07-29-2018 01:16 AM
Last Post: ladadens
  Mini control module swap i860 6 1,972 07-21-2018 08:07 AM
Last Post: i860
