  • 1 Votes - 1 Average
Mk60 abs coding
10-21-2017, 11:16 AM (This post was last modified: 10-21-2017 11:39 AM by jpderv.)
Mk60 abs coding
Hi folks purchased a touran and and tried to flash a hotstart fix file onto it I've done this many times and always worked before but on completion of the write I got an error that said conditions not met on mpps and so the usual car wouldn't start.
Flashed back the file that I had previously downloaded and car starts and runs ok but I have abs and traction control light on.
When I checked abs module with vagcom it says abs module incorrectly coded and in the coding section it just has 7 0's I followed the procedure for recoding with the vcds code helper and it accepted the code now on the abs module coding I have the code 0021190 instead of 0000000 but still traction control light is on and and light and it still says abs module incorrectly coded.
I've read some were once before that you can get abs code from your vin number I've tried searching but can't seem to find the info now when I need it unfortunately.
If anyone on here knows how to check the abs coding with the vin could you please help.
The code I got from the vehicle specifics was 0021190
The vin is WVGZZZ1TZ5W002672
Forgot to add that the car was previously tuned with someone else I know this is probably the cause of the whole handling
10-21-2017, 11:54 AM
RE: Mk60 abs coding
Please abs serial
10-21-2017, 12:22 PM
RE: Mk60 abs coding
long coding
323B0016092200FC001100EB901B0000000000
 Thanks given by: jpderv
10-21-2017, 06:17 PM
RE: Mk60 abs coding
(10-21-2017 12:22 PM)Helmivw15 Wrote:  long coding
Hi how do I enter long coding as when I go into abs control module the soft coding is just a number it doesn't say long coding like it does on some.
10-24-2017, 01:47 AM
RE: Mk60 abs coding
Bump anyone?
10-26-2017, 09:06 AM (This post was last modified: 10-26-2017 09:11 AM by Turkmin.)
RE: Mk60 abs coding
0021190 is correct coding by VINFing32 Or you can try 0021123.
Post here OEM order number.
If my post was helpful. Please Thanks+Rep buttons.
  vw golf 6 universal 2013 abs coding samux 3 484 Today 01:50 PM
Last Post: rasmoka
VW Mk20 abs coding 6n polo lgnd91 1 190 11-14-2017 09:53 AM
Last Post: ghassun
  Lost abs coding tiguan klaus65 4 4,938 11-09-2017 10:11 AM
Last Post: tmsvolk
  Long coding Golf 6 1.4 TSI abs venigo 3 235 11-09-2017 05:57 AM
Last Post: rabaukee
  Audi A1 abs long coding help maverickqwe 20 686 10-26-2017 11:48 AM
Last Post: maverickqwe
VW Jetta Abs/esb help needed coding lipidipi 3 348 10-23-2017 08:03 AM
Last Post: lipidipi
  ABS Long Coding AUDI A1 2010 - Coding Erased djdanny 5 2,106 10-03-2017 02:41 AM
  Golf 6 Coding ABS brylant238 2 186 09-28-2017 12:11 AM
Last Post: hoanganhtai
Seat Please help: Leon 5F ABS coding needed downtime 2 164 09-25-2017 05:28 AM
Last Post: rabaukee
VW VW Polo 1.4 ABS 6Q0907379Q coding needed jacek.olecko 3 179 09-24-2017 11:21 AM
Last Post: ghassun
