  • 17 Votes - 3.18 Average
Module corrupted
10-10-2012, 07:49 AM
Ford Module corrupted
While updating Power steering module the VCM lost connection and now power steering is not working. It is giving an error "Testman error 12 56 218936"
Next time I try to connect the VCM it is loosing connection.
ANy help is greatly appreciated.
10-10-2012, 01:54 PM
RE: Module corrupted
(10-10-2012 07:49 AM)dibun Wrote:  While updating Power steering module the VCM lost connection and now power steering is not working. It is giving an error "Testman error 12 56 218936"
have you tried to go back and reload orignal file back in
10-10-2012, 01:58 PM
Ford RE: Module corrupted
Yes I tried but IDS cant connect with the PSCM module.
10-10-2012, 07:02 PM
I'm sorry that this happened to you. It seems you have to see your local FORD dealer. You should always be aware what you're about to do with IDS, especially if you don't have all the documentation. This problem might be one that was created by the incapable FLY-VCM (in the second place). :tdown: My concerns have clearly been stated, see post http://mhhauto.com/Thread-ford-VCM-unabl...#pid83139. Headbang
I can't help you with that one any further...
10-11-2012, 01:43 AM
disconect the corrupt module and see if you can set ids up to install a new one maybe from the as built data,
when ids tells you to fit the new module fit the corrupt one and ids wil overwrite the corrupt data.
Good luck
10-11-2012, 06:01 AM
(10-11-2012 01:43 AM)Autotuning Wrote:  disconect the corrupt module and see if you can set ids up to install a new one maybe from the as built data,
Good luck
I dont have the build file. The Ford link doesnt work. How can I find where the module is located?
10-11-2012, 12:24 PM
Good luck
I can help you with as built file.
Givde me your VIN again.
Need help regarding pc problems, need any software that is not on net?
PM me freelyKolo
10-11-2012, 01:26 PM
Good luck
I have PMed you my VIN.
10-18-2012, 06:21 AM
Ford has changed the power steering pump free of cost and that solved the problem. Now the steering feels as of new car Smile
