  • 42 Votes - 2.6 Average
NEED ECU PINOUT DIAGRAM
04-22-2013, 02:51 AM (This post was last modified: 04-22-2013 03:35 AM by urcarpc.)
Opel NEED ECU PINOUT DIAGRAM
Has anybody got an opel/vauxhall meriva 1.3 cdti magneti marelli jtd 602 pinout wiring diagram? 2 days search through net but no luck still SadsmileSadsmile
probably the same as most other 1.3 marelli ecu's that are in opel and some fiat too.
Attached File(s) Thumbnail(s)
Tup Hit 'Thanks' and 'Rep+' If I have helped Fing32
04-22-2013, 03:10 AM
RE: NEED ECU PINOUT DIAGRAM
(04-22-2013 02:51 AM)urcarpc Wrote:  Has anybody got an opel/vauxhall meriva 1.3 cdti magneti marelli jtd 602 pinout wiring diagram? 2 days search through net but no luck still SadsmileSadsmile
see maybe help you
BR asto
MovieX-Tool Superprog and Upd.2017 for sale!!!PCR2.1 PIN,KM,CS,MAC1,MAC2,Iaw59F Dec.Tool,BMW/MB/Ren/CAN filter,Immo Off/calc.MEDC17 PIN/CS/MAC from dump,Audi BCM2,Nissan LCN Nav Dec. OMAP mcu,RCD310-510 decode or code off.DPF-EGR-Lambda OFF,serv. interval JCB v1-2.
 Thanks given by: ToMiBoY , urcarpc , wahye , allent , keano , inceser
04-22-2013, 03:39 AM
Thanks asto. I want to try reading the ecu flash data via obd , using k-line. This info is really good but which pin is k-line? Someone said its pin 31
04-22-2013, 04:20 AM
pin 5,6,23,50 12V , pin 1 Gnd , pin 88 K-Line
 Thanks given by: urcarpc
04-22-2013, 11:57 AM
Opel RE: NEED ECU PINOUT DIAGRAM
(04-22-2013 03:39 AM)urcarpc Wrote:  Thanks asto. I want to try reading the ecu flash data via obd , using k-line. This info is really good but which pin is k-line? Someone said its pin 31
Meriva ecu don't use k-line, its working with CAN thru imo, look at bosch diagram.You can't read ecu flash via obd using k-line. MPPS very well working with CAN, and coud easy read ecu flash.
Attached File(s)
Meriva.rar
File Type: .rar
Downloaded: 163 times
 Thanks given by: urcarpc , uszi69
04-22-2013, 12:33 PM (This post was last modified: 04-22-2013 12:45 PM by urcarpc.)
thanks again asto, I'l try that using obd on the table and see what happens.
autosistema, my mpps doesnt read full flash via obd in car. i only get about 468kb but need a full 2mb flash. I tried bdm with bdm3 adapter and xprog but it pulls back an error. this ecu is driving me nuts Sad
can a 12v universal adapter power the ecu?
04-23-2013, 04:43 AM
[quote='urcarpc' pid='137214' dateline='1366666422']
[/quote
i think this adapter is small ampere and see this screen ecu have same?,this is from fg tech galletto pinouts,pass pm
 Thanks given by: urcarpc , seba33 , inceser
04-27-2013, 04:18 AM
I got it to read via k-line obd but again it only gave me partial flash file. I tried bdm3 with xprog-m but even that threw back an error. So I finally gave up on this ecu
Thanks asto for all th help. Rep + from me Big Grin
04-27-2013, 10:35 AM
galletto 2 with ecu connected in the car----this gives a good read etc.enough for dpf off etc.
i have done this ecu in combo van 2008(caN)-read write perfect..
M.U.T.III ORIGINAL-FULL EUROPEAN MITSUBISHI DIAGNOSTICS
  Opel / GM E78 ECU Bench pinout for ID / Testing luc.b 2 61 09-20-2017 11:26 PM
Last Post: luc.b
  help pinout of ecu bosch m7.9.7.1 hugos31 1 70 09-19-2017 01:42 AM
Last Post: hugos31
Jeep Dash 2007 Jeep Liberty with mcu MC908AS60 need pinout sellerbay 2 78 09-14-2017 06:24 PM
Last Post: 2999keys
Chevrolet Dash - 2002 Yucon need pinout sellerbay 2 166 09-14-2017 09:35 AM
Last Post: sellerbay
  need pinout for sid206 Car-tech 0 51 09-13-2017 04:09 AM
Last Post: Car-tech
  Bosch ecu pinout Perry19 5 279 09-01-2017 05:36 AM
Last Post: PantelisX
  I need to find an access point. Find the SRS pinout. boycarry 3 217 08-19-2017 12:40 AM
Last Post: boycarry
VW I need pinout Passat B7 konrad199915.98 0 152 08-18-2017 09:39 AM
Last Post: konrad199915.98
  Jeep chrysler ecu pinout Perryking 1 148 08-16-2017 06:44 PM
Last Post: oaeelectronics
AA+MHH Functional diagram for ECU circuit board David Sun 0 248 08-15-2017 02:57 AM
Last Post: David Sun
