  • 1 Votes - 5 Average
Need CFF GLC x253 Headlights Left in bootloader
01-13-2018, 10:46 AM (This post was last modified: 01-13-2018 10:51 AM by fatal1ty.)
Hello all memebers,
May I know if someone have cff files to unlock my left ecu on my GLC X253
Ecu is in bootloader, someone tried to revive ecu but can't find cff I need.
E1n9>>left headlamp (SG-SW-L)
mb objet number for hardware 2539010500
mb object number for software 2539020200
E2n9>>right headlamp (SG-SW-R)
mb objet number for hardware 2229017901
mb object number for software 2539028900
Thank you 049
01-13-2018, 11:07 AM
RE: Need CFF GLC x253 Headlights Left in bootloader
I can help you contact pw please
MAP PIN COMAND ,SEED KEY , ADBLUE DPF OFF , VMAX, SCN coding, pin code radio
XENTRY 05.2018 INSTALL C4 , LAMP RETROFIT LED
Skype grajek41
 Thanks given by: fatal1ty
01-13-2018, 01:11 PM
(01-13-2018 11:07 AM)grajek4 Wrote:  I can help you contact pw please
Thank you so much for the files Wink 049Fing32
01-13-2018, 02:36 PM
Headlights need to be coded after flash so if u dont have saved codings then u need online or to work with coding after flash and it needs experience
01-14-2018, 12:32 AM
1-SCN online fail and go in bootloader.
2-Then flash via vediamo with right smr-f
and we got that error on vediamo after flashing (check in attachment)
So ecu seems dead (few people who know good told me Ecu is dead).
Do you think there is a way to revive ecu ?
If no solutions in few days i m going buy a new Ecu Sad TmiTmiCash
01-14-2018, 01:27 AM
Mercedes Benz RE: Need CFF GLC x253 Headlights Left in bootloader
You can pm me I will try to help you
(01-14-2018 12:32 AM)fatal1ty Wrote:  1-SCN online fail and go in bootloader.
Please press [Image: DdOoHyJ.jpg]buttons if my post helped Cheer2
01-14-2018, 02:02 AM
why would u flash this ecu? It can be broken, I agree, but usually it happens after water inside headlights or after crash
01-14-2018, 02:58 AM (This post was last modified: 01-14-2018 03:39 AM by fatal1ty.)
This car was invloved in crash, I repaired it, it was a front crash.
2 Headlamps were changed (same A part number) all modules were keept (like Led module and converter) but left control unit have been damaged.
So both headlamps have been changed and only left control unit was changed for a used one.
So if I can revive that control unit of the left lamp, it means I bought a broken control unit (that's possible because i bought not a new one from dealer but a used parts).
On the left side led stripes are not working.
When i put blinker to turn left it's not working too (in dahs indicator blink very fast).
Highbeam are not working also
Position light and normal beam are working only during scn programing before it fail.
Well I will buy a new control unit in few days at dealer Wink
Mercedes Benz 5s1 bin & cff files needed xDAS 9 811 Today 04:17 AM
Last Post: sherwin1111
  cff file alex111 2 520 04-09-2018 10:42 AM
Last Post: alex111
Mercedes Benz Headlights always on sonogenio 4 637 04-07-2018 12:45 AM
Last Post: erion
  Mercedes x253 GLC front crash some xentry fault help fatal1ty 13 1,097 04-04-2018 10:20 AM
Last Post: fatal1ty
  CFF files - get them while you can miltisus 70 8,793 03-29-2018 04:40 AM
Last Post: essie5
