  • 12 Votes - 3.33 Average
Need for help with X1 E84 2.8I does not start DME/CAS
01-11-2017, 09:31 AM
BMW Need for help with X1 E84 2.8I does not start DME/CAS
As the topic I have a problem with the BMW X1 2.8I 245PS USA. The problem is with how it is cold after a few hours to start at the moment that is 20-40S and go off automatically, later start time for 5-15s and again the same stop engine. for the 3rd time already is not possible only turns the engine and there are 2 errors:
0036CE DME internal error shutdown test by monitoring module
00332C terminal 15_3 line to the CAS electrical short circuit to ground
Checked connections do not have contact with the ground, the whole stool, like a beam of approx. It happened suddenly, after two weeks of not using the car.
Do you have any ideas?
If I helped you, please give reputation and Thankyou on my postThankyou i will too!!!
01-11-2017, 09:34 AM
RE: Need for help with X1 E84 2.8I does not start DME/CAS
Try to replace battery
01-11-2017, 09:45 AM
done,and the same;( IBS?
01-11-2017, 12:36 PM
disconnect the cable from the clamp ibs between two poles.
If you have read a post by anyone on this forum and it helped
please leave THANKS and REPUTATION, the two buttons below it takes only 1 second
its especially important to new users to recieve and give Smile Thanks Greg
01-11-2017, 12:51 PM
Thx, but was done toSad
01-11-2017, 08:07 PM
Check relay dme, and replace jbe module
01-11-2017, 10:17 PM
Realy ok all 31,30 and 15,15_3line IS ok , JBE i need bay i don't have one.
01-16-2017, 06:01 AM
JBE has not yet occurred to me, but today the car after firing 6-7minut worked about the first version of the display showed an error start / stop. Logically, such problems may generate in the car. what do you say?
01-18-2017, 12:34 PM
Any idea? Still the same problemSad
BMW BMW E65 no dme no egs eshikh 10 1,732 04-17-2018 09:58 PM
Last Post: kirukisu
  Bmw x5 2008 USA cas3 key remote not work.help ligitom 1 851 04-08-2018 11:56 AM
Last Post: temsky740
BMW E65 2003 CAS/ZAS problem. Cant swith ignition Dmitrij 0 926 03-19-2018 05:11 AM
Last Post: Dmitrij
  E92 Dead DDE/DME Replacement Help Please Sparks7766 0 856 03-18-2018 04:41 PM
Last Post: Sparks7766
  BMW e60 changing CAS 2 with CAS 3 bimmberworkshop 4 772 03-18-2018 07:40 AM
Last Post: bimmberworkshop
