  • 2 Votes - 4 Average
Need for help with X1 E84 2.8I does not start DME/CAS
01-11-2017, 09:31 AM
BMW Need for help with X1 E84 2.8I does not start DME/CAS
As the topic I have a problem with the BMW X1 2.8I 245PS USA. The problem is with how it is cold after a few hours to start at the moment that is 20-40S and go off automatically, later start time for 5-15s and again the same stop engine. for the 3rd time already is not possible only turns the engine and there are 2 errors:
0036CE DME internal error shutdown test by monitoring module
00332C terminal 15_3 line to the CAS electrical short circuit to ground
Checked connections do not have contact with the ground, the whole stool, like a beam of approx. It happened suddenly, after two weeks of not using the car.
Do you have any ideas?
If I helped you, please give reputation and Thankyou on my postThankyou i will too!!!
01-11-2017, 09:34 AM
RE: Need for help with X1 E84 2.8I does not start DME/CAS
Try to replace battery
01-11-2017, 09:45 AM
done,and the same;( IBS?
01-11-2017, 12:36 PM
disconnect the cable from the clamp ibs between two poles.
If you have read a post by anyone on this forum and it helped
please leave THANKS and REPUTATION, the two buttons below it takes only 1 second
its especially important to new users to recieve and give Smile Thanks Greg
01-11-2017, 12:51 PM
Thx, but was done toSad
01-11-2017, 08:07 PM
Post: #6
Check relay dme, and replace jbe module
01-11-2017, 10:17 PM
Post: #7
Realy ok all 31,30 and 15,15_3line IS ok , JBE i need bay i don't have one.
01-16-2017, 06:01 AM
Post: #8
JBE has not yet occurred to me, but today the car after firing 6-7minut worked about the first version of the display showed an error start / stop. Logically, such problems may generate in the car. what do you say?
01-18-2017, 12:34 PM
Post: #9
Any idea? Still the same problemSad
BMW cas internal error delimemet 5 134 03-25-2017 11:45 AM
Last Post: Cartronic
  BMW E53 diesel 0281011414 used DME and EWS sync notorious.jatt 8 154 03-20-2017 12:07 PM
Last Post: notorious.jatt
BMW cas 3+ leng007 2 102 03-18-2017 03:41 AM
Last Post: iyad.nasser
Mini 2012 Mini Cooper S N18 MEDV17.2 ECU SWAP, need ISN Sync with CAS, HELP!! NEED DUMP!! darmoyan917 39 871 03-17-2017 07:23 AM
Last Post: darmoyan917
  Used DME / DDE? Rkdiag1 3 124 03-16-2017 08:55 AM
Last Post: AutoHaus786
  JBBF CAS on the Table fl3xy 2 109 03-13-2017 12:24 AM
Last Post: nogger
  bmw 335i 2014 cas location please help me wphonetei 5 235 03-01-2017 11:18 AM
Last Post: tecnotronics
  e65 change the ecu and cas the central lock remot stor working how can i program it iyad.nasser 0 59 02-27-2017 08:30 PM
BMW BMW E92 New DME Failed Programming & Coding need help BMW LEARNING 1 138 02-17-2017 07:54 AM
Last Post: dimonmers
  bmw x5 dme ms43 virgin help me wphonetei 3 169 02-14-2017 12:27 PM
Last Post: sigaik
