  • 13 Votes - 4.08 Average
OFF-line program file for DAS 2013-3
06-03-2013, 12:52 AM
Mercedes Benz OFF-line program file for DAS 2013-3
Copy this file to F:\programme\das\trees\pkw\flashen\ini
Attached File(s)
inbetrieb.rar
File Type: .rar
Downloaded: 1273 times
 Thanks given by: sl6096 , billboard , Perona , ime-actia , tkinyan , coriducu , aatsjb8834 , bebetvas , rabihfiras , toderean , nabilrifi , autoseek , hasan shoubash , rhg , nashvic , flterence , hagop , teris , Pzolee , pesona , trinitron , sova , ivanko61 , jantech , megapali , daudi , euro-star , chevelle , Smallville , beongo , hbalazs , vik11 , Rocinante , avandgarde , darkeagle1005 , Albert595 , Milanezu , sbrenda , radani , camaro , aiklee74 , testariauto , Fjurie , abrarswl , vigo4d , taisuke-san , igoronavl , sweetsam , Pluto , Evi , alex_ng , 153771739 , ParisCY , Motasem , roofless , ranya , mbzboon , smlee747 , yublee , zaweel , encediag , fishingman , ToMiBoY , medsa , jinwang , mascanada , platas68 , volvosh , sec5klp , gerberauto , vincano , xxahmadx , Fouad , t1tan1 , maybach82 , wahye , ziegler , voevoda_alex , sage , mike gao , dgar , eckobo , Mootje , gooseyone , CyberLuk , checkersky , Andreseek , gazchab , kaseem757 , madmaxisback , Gobook
06-03-2013, 04:57 AM
RE: OFF-line program file for DAS 2013-3
I stand corrected , however does this fix work for versions past 09_2012. Thanks
06-03-2013, 05:46 AM
this fix donot work for versions past 09-2012,this fix only for das 2013-3
 Thanks given by: coriducu , teris , Rocinante , Milanezu , sweetsam , vincano , ziegler
06-03-2013, 06:56 AM
Hi,does it work with 7-g tronic control module replacement?
Can program it offline?
06-11-2013, 11:46 AM
this file run with all versions
and not is for offline scn, is for offline programming....
regards
 Thanks given by: Rocinante , brunofraga , salbutamol
06-13-2013, 09:33 AM
(06-11-2013 11:46 AM)audiomeca Wrote:  this file run with all versions
regards
Okey, I dont have much experience yet, so sorry for my stupid question 533
Whats the difference between SCN and offline programming?
I have a pretty good idea what SCN coding does, but what do I need this for?
- Digging for gold, throughing silver away -
06-14-2013, 04:35 AM
Mercedes Benz RE: OFF-line program file for DAS 2013-3
regards
Good afternoonCheer2
To educate yourself on both topics do a forum/google search---ther are loads of information on the subject, however a short answer is as follows:
SCN codes allows the control module you want to update or a new module to go into write mode, therefore allowing the module to be programmed---this process is all done while online repeat online and is seamless. Currently the only way to acquire the SCN code for the module and VIN is to be authorized with an account at MB. The SCN system was first introduced in 2007 and with every issues of DAS Xentry more and more models could not be programmed without an SCN code.
Therefore if you are working on an early 2007 car there is no SCN coding, just online and offline control module programming which is a completely different process.
Maybe this is more confusing---search and educate yourself first then ask some questions!!
 Thanks given by: autoseek , nae257092 , takis , bouzimeca , prgrm , beongo , Rocinante , Milanezu , stefans777 , sweetsam , jeff , getaibose , yieme , ToMiBoY , gerberauto , vincano , kahan , Fouad , GunMoto , s_vad
07-06-2013, 01:52 AM
hi i have a online account but i try to take away code and add new code for retrofit but i am able to takeaway but not to add code
please advise is my software or the access of the account problumb ?
thank you
regards
Please press [Image: DdOoHyJ.jpg]buttons if my post helped Cheer2
07-06-2013, 03:02 AM
What code is it?? Some of the lighting codes are not addable.. like LED DLR ect..
 Thanks given by: ToMiBoY , vincano , gcyauto
  Need software for CarDAQ 2 to program C300 DrahosR 4 261 02-16-2018 06:03 PM
Last Post: MBENZTECH
  Is DPF Off Possible with Xentry Das Sparks7766 7 557 02-03-2018 10:05 AM
Last Post: Sparks7766
Mercedes Benz MB DAS - Xentry 03.2013 Information + Solution Smallville 180 110,313 01-30-2018 10:09 PM
Last Post: user2468
Mercedes Benz Vediamo 5 and K-Line MIQMIQ 15 1,760 01-14-2018 09:04 AM
Last Post: MIQMIQ
  mb star c4 K line communication problem ruklis 2 326 01-09-2018 01:52 AM
Last Post: ruklis
