Opel Meriva 1.7 CDTI 2004
08-12-2017, 11:54 AM
Opel Opel Meriva 1.7 CDTI 2004
vehicle crank but not start.On the Real Data : rail pressure sensor 400 Bar. Code P0093 : Fuel System Leak Detected Large Leak
Sometimes vehicle start normally and while drive the engine shut off
Please can someone help me what is the real problem?
08-12-2017, 12:09 PM (This post was last modified: 08-12-2017 12:09 PM by Bibobabo.)
RE: Opel Meriva 1.7 CDTI 2004
Check the injectors for leakage. Whats with the fuel filter and the prepressure? Do you have the possibility to double check the railpressure? Last step would be to check the high pressure pump. Are there any solenoids or valves on the pump itself?
08-12-2017, 12:16 PM
(08-12-2017 12:09 PM)Bibobabo Wrote:  Check the injectors for leakage. Whats with the fuel filter and the prepressure? Do you have the possibility to double check the railpressure? Last step would be to check the high pressure pump. Are there any solenoids or valves on the pump itself?
strange is that the rail pressure says 400 Bar on engine off
08-12-2017, 12:34 PM
Sensor broken or short/open circuit. Try to unplug sensor and look again for that value. Measure the voltage on sensor plug. Should be 5v
 Thanks given by: florionk
Opel opel meriva 1.7 cdti service manual.. Please!!! florionk 0 45 Yesterday 10:50 AM
Last Post: florionk
  Opel vauxhall meriva 2004 flashing sign (F) on dashboard car can't crank HIGH TECH AUTO 28 534 08-14-2017 09:44 AM
Last Post: andyl
Opel Repair tips for EPS Corsa / Meriva 1.7D hzelectronic 0 107 08-02-2017 05:02 PM
Last Post: hzelectronic
  help my probleme hot start 1.7 cdti 100cv Bigcam 4 90 07-17-2017 02:39 AM
Last Post: telucu17
Opel opel vectra C 2004 sholarx 1 172 06-04-2017 09:51 AM
Last Post: builes13
Vauxhall vauxhall vectra 1.9 cdti batrst 6 213 04-30-2017 01:35 AM
Last Post: batrst
  Need PIN from VIN Opel Meriva - I will pay gelomeloman 2 280 04-20-2017 08:33 AM
Last Post: gelomeloman
Opel Opel Vivaro 2.5 cdti EGR terrorfirmer 1 189 04-18-2017 04:50 AM
Last Post: skitzo
Opel Opel meriva B 2012 1,4 turbo HG-Automotive 1 210 01-28-2017 02:03 PM
Last Post: vizyon
  Opel Vectra C 3000CDTI V6 24v CDTI 177CV robertos2000 3 202 01-20-2017 11:50 AM
Last Post: robertos2000
