  • 35 Votes - 2.77 Average
Opel zafira 2000 2.0L diesel doesn't start
08-04-2012, 06:33 AM
Opel Opel zafira 2000 2.0L diesel doesn't start
Hello
One friend has a problem with his opel zafira diesel year 2000 130 000 KM:
Fault P1630 (diesel pump)
Is it possibel to fix by your own that EDU (ECU) on the fuel pump ?
I saw on internet they fix it... but no information ...
In advance thanks !
08-04-2012, 09:29 AM (This post was last modified: 08-04-2012 09:30 AM by sokisoki3.)
RE: Opel zafira 2000 2.0L diesel doesn't start
is the edu on the top or on the side of the pump?
08-04-2012, 09:31 AM
on the top .
08-04-2012, 09:43 AM (This post was last modified: 08-04-2012 09:44 AM by sokisoki3.)
so there is no edu. It is vp 44 and the fix on it is possible but.... It is possible to repair ecu from the top of the pump. but failure of the transistor is mostly caused by mechanical sticking/seizing regulator which seats on the back of the pump.
08-04-2012, 10:05 AM
Possibel by self fixing ? For the pump they ask in Belgium 1500 euro ... only for pump without work ...
08-04-2012, 10:44 AM
yes possible fix the transistor but as I said it might fail again. What about fitting second hand pump?
08-04-2012, 09:50 PM
And can you tell me more about fix transistor ? Second hand for how much kilometers ...
08-04-2012, 10:39 PM
there is no such a rule how lon will it work for . It may break after 1 mile it could still lrun foir longer. I did try this -only transistor and van-transit comes back after one week. But have a look
http://www.youtube.com/watch?v=UiJ-13vldWg
08-04-2012, 11:06 PM
Ok will try first with transistor ! Thank you !!!
Vauxhall zafira pump psg16 replacement and programming sokisoki3 72 60,050 Yesterday 05:34 AM
Last Post: andyl
Vauxhall Zafira B 2009 Z19DT DPF Stephenlevi1981 9 209 08-11-2017 11:36 AM
Last Post: Stephenlevi1981
Opel Zafira B 1.7DTR Dead , no Crank,no power on dash plasticman1971 15 237 08-04-2017 05:57 AM
Last Post: liviu2004
  vin to pin - zafira sokisoki3 36 10,861 07-29-2017 02:53 PM
Last Post: mecsoun
  2003 Saab 93 sport Diesel no start koziolek 8 202 07-21-2017 12:53 PM
Last Post: Radiosolutions
Opel dtc off Opel Zafira EDC16c9 PIMPin89 5 205 06-07-2017 09:34 AM
Last Post: PIMPin89
  Opel Astra G don't start geneluauto 6 202 05-26-2017 07:57 AM
Last Post: geneluauto
  2000 dodge Central timer module waybux 1 106 05-23-2017 07:56 PM
Last Post: waybux
Opel Opel corsa c won't start tome 12 427 05-15-2017 05:15 AM
Last Post: tome
Opel Opel Zafira B A17DTR wiring diagram &DPF OFF AndreiStefan 1 199 05-13-2017 11:54 PM
Last Post: svvag2000
