Outlander 2 cw7w ac authorisation prohibit
06-18-2017, 10:41 PM
Hi, i have an 2011 Outlander with 2.2PSA group engine. Yesterday the AC compressor refused to crank, checked all fuses/relays/and ac/engine diagnostics, all ok. No errors.
On live data (engine) shows me on A/C authorisation : prohibit;
All pressures are ok, temp sensors reading fine;
I've started the compressor from engine relay, and works perfect.
What should I check?
06-22-2017, 01:52 AM
RE: Outlander 2 cw7w ac authorisation prohibit
Solved : ETACS has bad coding, now, how do I code it?
06-29-2017, 04:25 AM
If you have mut III its easy. Etacs -> Special functions -> Koding or variant coding and there you have to change in "air conditioning" ->absent to present
06-29-2017, 05:18 AM
Solved, with an techstream clone J2534 and software from etacsdecoderDOTcom
Misubshi 2007 Mitsubishi Outlander 2.0DI-D- short glow plug time Danthe 6 252 01-08-2017 03:43 AM
Last Post: Danthe
  CODE P1676 Variant Coding System after replaced new ecu (mitsubishi Outlander 2009) legendz 0 703 01-12-2016 12:59 PM
Last Post: legendz
Misubshi Mitsubishi outlander 2007 chip making? r.arbnor 4 1,205 05-09-2015 09:42 AM
Last Post: Levon
  outlander o2 sensor mrserii 1 675 04-06-2015 11:42 AM
Last Post: Danthe
Misubshi Mitsubishi Outlander FAP 22D130kw Denso igracek 0 757 01-07-2015 12:27 PM
Last Post: igracek
Misubshi Mitsubishi Outlander dbirke 0 966 01-29-2014 10:34 PM
Last Post: dbirke
Misubshi MITSUBISHI outlander batko 3 2,691 10-22-2013 04:32 AM
Last Post: robert02500
