  • 51 Votes - 3.02 Average
PSA Interface checker
12-28-2012, 12:13 PM
Citroen PSA Interface checker
I have Diagbox v.6.24 installed succesfully on my computer, however my clone interface don't work at the moment. Somebody told me I have to use PSA interface checker to update my interface. Offcourse I found a download on the internet, but it's secured with a password.
Can someone help me to get the right password?
And how does it work?
Offcourse I did my reading on this forum, and discovered that Scary Mistake can flash an clone interface to an original interface by sending it to Mr.Scary. What's the price for that, and where do I send it to?
Please Mr. Scary HELP ME!
Best regards from the Netherlands!
 Thanks given by: mattydr67
12-28-2012, 01:19 PM (This post was last modified: 12-28-2012 01:20 PM by coriducu.)
RE: PSA Interface checker
(12-28-2012 12:13 PM)Jay-Jay... Wrote:  I have Diagbox v.6.24 installed succesfully on my computer, however my clone interface don't work at the moment. Somebody told me I have to use PSA interface checker to update my interface. Offcourse I found a download on the internet, but it's secured with a password.
this checker is just to check your version of firmware not help at all for what you need , and can just upgrade or downgrade firmware
your clone not work cause you need to flash your interface and this is other procedure who is made in other way
just try contact scary cause he is "GOD FATHER" of this and he will fix your problem
btw: send him a pm cause here he will not answer you on this problem
 Thanks given by: Jay-Jay... , mattydr67 , mladen76
12-28-2012, 04:06 PM (This post was last modified: 12-28-2012 04:08 PM by mattydr67.)
Jay-JAy
The password it is allways the same. ( scary01 )
But this tool is for check the firmwear and serial and as your tool's dosen't working with that version of Diagbox you can use the PSA checker to downgrade the firmwear to 4.2.4
The firmwear is changed automatically by the Diagbox softwear when you need a higher version of firmwear you don't need to do it by yourself. So the PSA Checker you can use it to downgrade the tool
Contact Mr. Scary by PM and you'll smile. Your are in the "neighbourhood"
Good luck
 Thanks given by: mladen76 , Geri , rob387
10-08-2015, 10:36 AM (This post was last modified: 10-08-2015 10:40 AM by Anton69.)
Citroen RE: PSA Interface checker
Everyone says use Scary`s interface checker. GREAT!!!! Where do I get it from?
Can anyone tell me where to download interface checker from.. Apparently I need to reflash my VCI but I have no idea what that means either. Nobody explains how to do this.
Ant
10-08-2015, 10:47 AM
Ant
Hello.....Please read here first then reply over there to make sure you have understood
http://mhhauto.com/Thread-Yet-another-Diagbox-thread
That's not how it works, that's not how any of this works
 Thanks given by: diagnostix
10-08-2015, 11:04 AM
Ant
Thank you very much.
Peugeot EDC16C34 EGR DPF OFF PSA strruja 3 118 08-19-2017 04:19 AM
Last Post: strruja
  PSA same computer? iRik 2 115 06-20-2017 11:04 PM
Last Post: Stelaras
Peugeot PSA Ecu Pin Calculator looking1977 1 521 04-18-2017 11:02 PM
Last Post: Stelaras
Citroen PSA Service box seli1 5 799 01-11-2017 03:15 AM
Last Post: Segadora
  PSA BSI Tool for Peugeot Citroen Odometer, PIN, Key program support 53 58,966 12-21-2016 12:33 PM
Last Post: Ben101004
  VDDI2 PSA function Kim1980 0 318 11-16-2016 06:27 PM
Last Post: Kim1980
Peugeot PSA VIN Check ricardo cruz 6 694 11-07-2016 01:30 AM
Last Post: ricardo cruz
  Database bsi psa flash dumps Abdou37 0 474 10-29-2016 12:47 AM
Last Post: Abdou37
  sbb for psa cars after 2010 rokibar 1 367 10-10-2016 10:13 AM
Last Post: gimba
  PSA 2,2HDI EDC16CP39 fap and off? Vitalyr133 0 437 10-02-2016 04:07 AM
Last Post: Vitalyr133
