  • 8 Votes - 2.75 Average
Peugeot 407 FAP/DPF additive system
04-04-2013, 05:32 AM
Peugeot Peugeot 407 FAP/DPF additive system
I have Removed the DPf filter out of a 2005 Peugeot 407 2.0 HDI, the Siemens SID803 has had the DPF removed from its config.
I have a problem with the eolys, DPF additive system flashing on the dash that it needs fluid level filled.
I have filled the system but i am unable to find where to reset the counters? i am also unable to communicate with the BSI of the car using PP2000.
has anyone come across a problem like this before?
thanks
04-04-2013, 12:41 PM
RE: Peugeot 407 FAP/DPF additive system
hi,
there is no need to fill ..
Unit does not additive levels, but only counts the time and mileage.
the configuration of the set adivace 0 g-Additive (new fap) and additives added.
and in BSI configuration without fap!
04-07-2013, 06:01 AM
(04-04-2013 12:41 PM)homisek Wrote:  hi,
When I go to set to 0g it says to me that this cannot be configured? And I can't talk to the bsi with pp2000? Any ideas?
04-07-2013, 09:20 AM
Peugeot RE: Peugeot 407 FAP/DPF additive system
I usually reset the counters in the additive ecu "add to go"
In the add to go ecu select "configuration"..."manual configuration" and reset both counters to zero..then hit the configuration icon on the bottom of the screen..all done...Wink
Ron.
04-07-2013, 11:24 PM
Ron.
Thanks Ron, I get 'no reply from Ecu' when trying to connect to the additive Ecu? Should a 2005 RHR 407 have this Ecu? Pp2000 says to do a global scan to determine if one is present but it doesn't reply.
04-20-2013, 11:55 AM
es posible que no tenga ecu funciona con ecu motor entra en fap y poner contador aditivo a 0 despues abrir tapon deposito gasoil durante 10s y si se reposta mejor
04-20-2013, 03:54 PM
When the DPF was removed from your system, the additive ECU was not removed from the system by looking at this post! Sometimes the additive ECU freezes so you need to disconnect the plug and reconnect it.
653 If I helped you please click Thanks or give me reputation please! I do it when someone helps me!
06-11-2013, 07:48 PM
Hello.
I want to get info about the DPF and additve-system. Want to know how many percent full the dpf is. How i can do an regen with the pp2000? How much is left in the additive tank.
I have tried this:
Test via ECU
Engine/Gear
ECU Diesel Additive
Then i get:
ECU not respond-have you choose right system?
But i dont get any list or option to choose from.
I have the meny in Swedish, so i dont know if the translate is correct.
Hope some can get me some hint.
I have no problem with the reading and deleting of fault codes, or reseting of service with this pp2000.
The car is a 407 HDI 2007. VIN-VF36ERHRH21614247
Citroen Citron C5 2.2HDI 2002 disable the fuel additive with Lexia sam_1 3 151 02-02-2017 03:36 AM
Last Post: plagu
Peugeot Peugeot 407 2.0i IAW 6LPB Original File? khaledauto 2 141 01-18-2017 01:36 AM
Last Post: khaledauto
Peugeot 407 engine fan Start late at 114°c ! khaledauto 7 188 01-14-2017 03:57 AM
Last Post: makssenior
Peugeot need help about FAULT code peugeot 407 U1208 hafido1983 7 169 01-13-2017 12:28 PM
Last Post: hafido1983
  Peugeot 407 Webasto nilsson 0 118 01-08-2017 01:55 AM
Last Post: nilsson
Peugeot Pin Code for 407 1.6 HDI Plus DPF delete alexvf750 4 189 12-11-2016 09:59 AM
Last Post: alexvf750
Peugeot Deactivate Airbag warning Peugeot 407 2007 david.obd2 0 143 11-28-2016 05:17 AM
Last Post: david.obd2
Citroen C5 X7 Tourer 2.0HDi 140 FAP DPF regeneration bekiyu 1 154 11-12-2016 11:30 AM
Last Post: jonce1555
  peugeot 407 unlock by itself after 5 minutes mikroel 7 524 10-14-2016 03:00 AM
Last Post: jumpy1
  Peugeot 508 1.6 hdi fap location Tancho 2 199 10-12-2016 08:55 AM
Last Post: Geza
