  • 31 Votes - 2.55 Average
Pinout of ecu 206
11-23-2012, 01:25 AM
Peugeot Pinout of ecu 206
To enable cruise control on my Peugeot 206 1.6 16v NFU 2001, I need to wire an extra brake switch to the ecu.
Does anyone have the pinout of the ME7.4.4 ecu?
11-25-2012, 10:40 AM (This post was last modified: 11-25-2012 10:43 AM by dib47.)
RE: Pinout of ecu 206
(11-23-2012 01:25 AM)Rolf Wrote:  To enable cruise control on my Peugeot 206 1.6 16v NFU 2001, I need to wire an extra brake switch to the ecu.
Hi. You need a 2 pole switch with a fused ignition supply (fuse 3 in engine bay for factory fit) switched to terminal m1 on the engine ecu. Please note this is a normally closed switch so there will be +12v to pin m1 all the time the ignition is on & the brake pedal not pressed. If you can't get an original switch you could do this with a relay, but not recommended for safety reasons
sorry, should have said this is pin m1 on plug B, the middle of the 3 plugs on ecu
 Thanks given by: Rolf
11-26-2012, 12:07 AM
Thanks.
I'll replace the original 2 pin switch with the OEM 4 pin switch that's intended for cruise control.
So the continuous 12v is not the problem.
 Thanks given by: diagprog2000 , electromovil
  Peugeot 206 A/C not working kalabalak 1 152 07-24-2017 09:26 AM
Last Post: Adrian_b
  Peugeot 206 purge canister valve nikola_bb 5 1,054 07-06-2017 11:27 AM
Last Post: cea7860
Peugeot Peugeot 206 1.4i (TU3JP KFX) stalls when turning on AC or lights robertot5 52 8,993 06-12-2017 10:55 AM
Last Post: AfXv237
  need pin code pejo 206 bsi siemens mplinux 1 191 05-23-2017 05:48 AM
Last Post: david123
Peugeot Peugeot 206 immo help vanadzor 2 213 05-16-2017 06:02 AM
Last Post: vanadzor
Peugeot Need PIN FOR 206 FROM VIN PLEASE mani876 0 206 04-20-2017 12:33 AM
Last Post: mani876
Peugeot Help 206 bsi 95160 change to 82123km jamechan 1 227 04-05-2017 12:40 PM
Last Post: alllex21
  peugeot 206 1.9d WJY 2001 P0122 error marcmu 0 263 04-05-2017 10:28 AM
Last Post: marcmu
  lexia3 on peugeot 206 1.4 hdi problems alexvf750 3 236 03-22-2017 10:26 AM
Last Post: alexvf750
Peugeot (Solved) Peugeot 206+ 2010 Airbag-Error 803 Ilja 3 376 01-07-2017 03:39 AM
Last Post: Ilja
