To obtain your Invitation code, please send a request to: webmaster@mhhauto.com
Please Read the forum Rules before you register. Be aware that not adhering to forum rules might result in Banning your Membership.
Latest news: --- Mercedes EPC (04.2013) install problem --- MERCEDES -BEZN E320 2004 SBC fault code c2131 --- Dash bmw 530d e39 --- perkins2012a. --- Timing Calibration for C15 3406E --- Autocom cdp pro not working properly please help --- help to immo off nissan almera tino 2.2d --- Renault 1.9dci 130 DPF/FAP --- help for immo off renault kangoo 1.9 dci --- Suzuki Liana Landirenzo Omegas plus --- Help With 11/2012 Xentry/DAS and C3 Mux --- Manuel SSP SSP 153 (Engine 1,9 ltr-TDI-Industrial) --- Seat 5N0959655AA - Crash Data --- EIS FLASHES if someone need. --- Hyundai Getz 1.5 CRDI immo off - anyone? --- [Request] Chevrolet Pick up C10 Manual --- Galletto 2 Master EDC17 --- Ccc pathways estimating system??? --- DiagBox User Manual --- BEGINNERS GUIDE TO USING WINOLS --- audi a6 2007 2.7tdi tuning file request --- Mb W210 C1306 fault --- 307 pin code --- Dash 999999 km problem --- Help on Autocom and Carprog --- skoda roomster radio code --- Peugeot 407 - Peugeot Planet 2000 --- AUdi A4 1,9 tdi 85 kw Chip tuning file --- Looking for chevrolet USA EPC --- Audi A4 BCM2 IMMO 5th generation unit swap --- VW Golf V - Plus - Cady - Jetta service manuall --- BENZ EGS ISSUSE HOW FIX ? --- need some help with immo Off please ! MED17 --- ASTRA G KEY TRANSPONDER --- benz C204_DPF repair.... --- newer e2m/ecfg file for cm870 --- IMMO OFF IVECO 3,0 hpi --- CAT ET 20XX XX --- FSC Enabling codes DVD --- Porshe_boxter_ecu_95P08 --- [Request] RENAULT MEGANE 2 Pin Code --- P206, 1.4 Motronic 7.3 Doesn't start --- Request - diagram for chain points Kyron 200xdi 2006 --- Xentry 07/2012 internal error 3.1 - 3.8 --- Audi A4 B8 2009 MMI BASIC more language --- injectors common rail database --- coding for trans --- Autocom Update 2.13.1.1 - Problem --- Autocom Update 2.13.1.1 - Problem --- Anyone nows what kind of delphi ecu a Ford Transit 2.4L Diesel 101KW has? ---
