  • 3 Votes - 3 Average
Problem with dpf off Siemens ppd 1.2
06-19-2017, 11:46 AM (This post was last modified: 06-19-2017 12:42 PM by m35i.)
Hi, I make dpf off in passat year 2006 BMR ( Siemens ppd1.2) with DPF REMOVER all is ok no fault and the car is perfect, but the light of dpf in cluster is ON , how I can solved this??
I try make regeneration before dpf off without lucky
Any have idea?
passat ppd1.2.rar
File Type: .rar
Downloaded: 10 times
06-19-2017, 12:01 PM
RE: Problem with dpf off Siemens ppd 1.2
free software- bad software
----------I do not know anything-------------
bcm2 elv adapt online -echange immodata -clone immodata sinchro bcm elv medc17 edc17 -DPF/ EGR/ DTC/ removal/: IMMO OFF:edc15 edc16 EDC17 edc17c64 NOW WORKING MED17/MEV17/ VAG ecu clone full working all
prc2.1 adapt, clone, etc / dash with micronas ou nec echange immodata etc etc
 Thanks given by: @batterypack@
06-19-2017, 12:04 PM
you want to delete dtc for dpf
post your file new
Official WinOLS owner - 1000hp 4x4 Dyno owner
Official CMD - KessV2 - Ktag - Magpro
skype : builes154
 Thanks given by: m35i
06-19-2017, 12:07 PM
Hello
Did you try with sensors removed? DPF REMOVED is not that good
send .ori and file generated with DPF REMOVED to I can check that for you
Do you need High Quality Diag tools directly to your door ?
Do you need Help for instalation or formation or Teamviewer service ?
PM me for an Appointment
79 please if I help don't forget thank's & reputation 79
06-19-2017, 12:46 PM
(06-19-2017 12:07 PM)Stinger88 Wrote:  Hello
Hi thanks for you reply , i post the two dumps.....
06-19-2017, 12:50 PM
start the car and run 30 min the light is ok
06-19-2017, 12:57 PM
(06-19-2017 12:50 PM)barek2009 Wrote:  start the car and run 30 min the light is ok
yes i make without lucky , with dpf file and file ori.....
06-19-2017, 05:57 PM (This post was last modified: 06-19-2017 05:58 PM by Stinger88.)
Hello
please don't forget to correct checksun with your tool
Attached File(s)
PPD 1.rar
File Type: .rar
Downloaded: 8 times
06-19-2017, 08:59 PM
All automatic programs are not good, only custom file servis. Did You reset carbon mass filter before reprogramming? May by this is the problem.
VW VW Golf 1.6SR Siemens 5WP4 immo off need Mirican 3 179 Today 03:58 AM
Last Post: Mirican
Audi Request VDO Siemens Simos6.2 immo off Help! taisuke-san 0 88 08-17-2017 08:44 PM
Last Post: taisuke-san
VW Siemens Simos 3.3 Immo Off Regulator 13 949 08-16-2017 09:50 PM
Last Post: Knubbe
VW IMMO OFF SIEMENS 5WP4 256 strikeforce 6 1,381 08-15-2017 03:27 AM
Last Post: spider-wifi
  Siemens 5WP4 3B0907557 - Immo Off jaxone 2 113 08-14-2017 11:54 AM
Last Post: MK2-VRT
  immo off cady 1997 Siemens 1H0953257BB morrisonjmk2 8 179 08-13-2017 06:55 AM
Last Post: morrisonjmk2
VW siemens 5wp4332 immo off craciunaero 1 96 08-04-2017 12:12 AM
Last Post: mansens198803
VW SIEMENS 5WP4448 03 IMMO off HELP esad.zilkic 1 112 08-03-2017 11:22 PM
Last Post: mgor
  SIEMENS SIRIUS 34 IMMO OFF HELP. Pro.chiptuning 7 237 07-28-2017 03:54 AM
Last Post: Pro.chiptuning
VW Vw Touran 1,6 Petrol siemens simos 7.1 immo off Juonio 2 139 07-27-2017 11:24 PM
Last Post: lednew
