  • 2 Votes - 1.5 Average
Programming bcm Buick rendezvous
09-19-2017, 12:05 PM
Buick Programming bcm Buick rendezvous
I have an 02 Buick Rendezvous. Bcm was bad causing all sorts of electrical issues. Used tech2 to pull info with SPS. installed new bcm. Everything working. Runs without security light or vats issue.
Question is when trying to program in tis2000, did not give me an option for bcm. Only pcm/vcm and security? Is this normal? I know it's an older car but it's in great shape and was a really low price.
Any help would be greatly appreciated.
09-19-2017, 11:17 PM
RE: Programming bcm Buick rendezvous
The BCM of the old model doesn't need SPS.
 Thanks given by: rw417
09-23-2017, 09:19 AM
(09-19-2017 11:17 PM)cqlp82 Wrote:  The BCM of the old model doesn't need SPS.
I figured that out thus far. Haven't been able to get back into the shop to work on it since, but everything is working. In the tech2, it is my understanding I need to code the module? activating different features inside the body section of the tech2? do you have any tips to make sure that is done properly? I can track down the rpo codes if that is what I need.
I appreciate the help
09-23-2017, 04:09 PM
You just need to use TECH2 to set up RPO for BCM. Then there is the main key code that might need to be configured with airbags.
09-23-2017, 04:50 PM
(09-23-2017 04:09 PM)cqlp82 Wrote:  You just need to use TECH2 to set up RPO for BCM. Then there is the main key code that might need to be configured with airbags.
Thanks! Keys worked right out of the gate and had no security or air bags indicators. I will check into it next week. Thanks so much for your help
Chevrolet Cruze virgin BCM! khaledauto 7 130 Today 05:29 AM
Last Post: khaledauto
  2004 Buick Lesabre Cluster power up diagram bradsmith 5 181 09-04-2017 09:08 PM
Last Post: clusters
  BUICK ENCLAVE 2008 ECM Swap with Used one DANITO 3 181 08-07-2017 01:38 PM
Last Post: hasoon2000
Chevrolet How to Repair General Motors (Chevrolet Cruze, Opel,Buick,GMC,Vauxhell......)car BCM David Sun 2 1,474 07-26-2017 07:26 AM
Last Post: David Sun
  insignia pin from bcm djolevv 5 349 05-17-2017 02:01 PM
Last Post: djolevv
Opel bcm zafira 1.9 dth distribrecon 1 237 02-16-2017 07:52 AM
Last Post: liviu2004
  vectra c bcm pin code gimba 12 871 11-20-2016 12:03 AM
Last Post: Geza
Buick Buick Lucerne 2006 issue PCM or TAC?! ofekr 0 407 07-09-2016 07:42 AM
Last Post: ofekr
  Help with GM BCM variant coding and programming terboguy 2 770 05-13-2016 03:20 PM
Last Post: terboguy
  Replacing defective ECU in 97 Buick Century. e500 2 519 04-22-2016 11:33 AM
Last Post: e500
