  • 1 Votes - 2 Average
RLS fault code -> Re-Adaption failed (with Vediamo and Xentry)
01-11-2017, 11:11 AM (This post was last modified: 01-13-2017 12:18 AM by wuerfel.)
Mercedes Benz RLS fault code -> Re-Adaption failed (with Vediamo and Xentry)
Hello, i hope, someone can help!
After i have changed some codings in the SAMF_172, i get two error codes:
--> B221D54 (rain sensor no calibration) and B221D49 (rain sensor electric problem) - Clear the error codes is not working.
So, i try to repair it with XENTRY 09/2016 and VEDIAMO 5.00.06.
But both has failed.
Vediamo can't make a "re adaption" and Xentry has "abort the calibration", too. But, why?
Can i damage the RLS with a wrong coding?
What i have changed, was "RLS sensitivity"[light and rain] and "Windshield transmission". Now, all that, i have switch to the defaults.
Now i only want make the re adaption...but it doesn*t work.
Any ideas?
MANY THANKS
Attached File(s) Thumbnail(s)
# Retrofit and coding with Vediamo and XENTRY – also with TeamViewer on your computer.
01-11-2017, 05:17 PM
Mercedes Benz Why?
(01-11-2017 11:11 AM)wuerfel Wrote:  Hello, i hope, someone can help!
Any ideas?
MANY THANKS
Hallo,
Try to disconnect battery for 10 minutes and connect it back. Then see if the fault still here and then go with adaptation etc etc.
Hope this can help.
Drive Press the Thanks and + If I really Help You.Kolo
 Thanks given by: wuerfel
01-12-2017, 01:08 AM (This post was last modified: 01-12-2017 01:08 AM by wuerfel.)
RE: Why?
(01-11-2017 05:17 PM)MegaCar Wrote:  Hallo,
Hope this can help.
OK. I'll try it later and write back here.
But, if this is not the solution, what can i do? Must i change the RLS, then?
01-12-2017, 01:58 PM
RE: X204 - RLS fault code -> Re-Adaption failed (with Vediamo and Xentry)
Hope this can help.
1)
So....it helps! Nod
But i think, its an bug in XENTRY.
Why? --> Always when i try to re-adapt the RLS, this two errors come back.
After that, when i only disconnect the RLS and reconnect it, the error is gone or can be deleted and the sensor is working.
So, its not a "coding"-problem. But, I must not use the re-adapt function in Xentry.
2)
What do you say to the RLS in the picture? Its not ok, isnt it?
01-12-2017, 04:36 PM
Mercedes Benz RE: X204 - RLS fault code -> Re-Adaption failed (with Vediamo and Xentry)
Hope this can help.
1)
So....it helps! Nod
2)
Try to use latest Xentry, may be this can help you. but am not sure. Good Luck
01-13-2017, 12:19 AM (This post was last modified: 01-13-2017 12:20 AM by wuerfel.)
RE: RLS fault code -> Re-Adaption failed (with Vediamo and Xentry)
I use 09/2016.
Whats the best way to update "offline" to 12/2016 (here are too many threads about that...).
And: What do you say about the picture?
THX!
Mercedes Benz Zolookas XENTRY installation Guide for 03_2014 Xentry apple 81 49,899 Today 08:15 AM
Last Post: avandgarde
Mercedes Benz 2017 Xentry/WIS/EPC/DAS/Vediamo/Monaco DTS/SDConnect Help Links Rocinante 3 8,360 Today 06:51 AM
Last Post: Rocinante
Mercedes Benz DAS initialization of diagnosis multiplexer failed BareBone 2 140 07-15-2017 08:37 AM
Last Post: Dollsburg
  vediamo 4 and 5 side by side ponyboy3 10 309 07-12-2017 11:55 AM
Last Post: ponyboy3
Mercedes Benz Xentry 2016 07 He continues to lose the license of Xentry and Ewa pijey 5 419 07-06-2017 06:29 AM
Last Post: pijey
Mercedes Benz W212 IC_204 after failed flashing dead amcad 20 726 07-03-2017 09:55 AM
Last Post: Jake5555
  W204 ''MIL'' setting in Xentry/Vediamo Dollsburg 8 503 07-02-2017 02:21 AM
Last Post: Jake5555
BMW Mercedes 220d fault code P263509. New to MB krug 3 242 06-30-2017 12:23 PM
Last Post: krug
  W166 remove option 468 Active driving stability in XENTRY or Vediamo tferrari 2 165 06-08-2017 02:42 AM
Last Post: tirex2k
Mercedes Benz Access/Edit EOL Values Euro6 Trucks with VEDIAMO xentry smartcard 7 489 06-02-2017 05:53 AM
2 Guest(s)
