Ranger 3.2 Duratorq TDCi - Help
08-12-2017, 07:20 AM
Hí to all. I am mechanical repair.
I need your help, please.
Ranger 3.2 Duratorq TDCi , failed during DPF static regeneration !!!!
Vaporizer Pump is blocked !!! , no duty-cycle during regeneration !!!
No falty codes in memory by ECM
checked relay and fuses, all Ok
some help ?
If my post Helped you, please press thanks button, thank you Tup
08-12-2017, 07:29 AM
RE: Ranger 3.2 Duratorq TDCi - Help
theres an injector by dpf , check if its blocked
08-12-2017, 09:46 AM (This post was last modified: 08-12-2017 09:47 AM by Joao Antonio.)
(08-12-2017 07:29 AM)@batterypack@ Wrote:  theres an injector by dpf , check if its blocked
Ok, checked injector, wires , glow plug.
The problem is, no signal PWM of ECM to vaporizer pump !!!!
08-12-2017, 09:55 AM
what happened to this
Vaporizer Pump is blocked !!!!
08-12-2017, 01:14 PM (This post was last modified: 08-12-2017 01:17 PM by Joao Antonio.)
(08-12-2017 09:55 AM)@batterypack@ Wrote:  what happened to this
Yes, not works !!!
Hi friend, I have problems during static regeneration, the regeneration process is not performed because the DPF temperature does not exceed 200 degrees, the PCM control module does not send the signal to the vaporizer pump to work, to inject liquid Diesel into the DPF.
Engine PCM is "Fomoco"
any help ?
08-13-2017, 11:11 AM
Had a similar problem with an 2011 smax,regen would get about 90% done then fail,the injector in the exhaust kept blowing a fuse,had to replace injector and fuse,cant remember what fuse is was but it wasn't labelled anything to do with the dpf system,I suggest you throughly check your fuses again just in case
08-14-2017, 03:30 PM (This post was last modified: 08-14-2017 03:31 PM by Joao Antonio.)
(08-13-2017 11:11 AM)Colin C Wrote:  Had a similar problem with an 2011 smax,regen would get about 90% done then fail,the injector in the exhaust kept blowing a fuse,had to replace injector and fuse,cant remember what fuse is was but it wasn't labelled anything to do with the dpf system,I suggest you throughly check your fuses again just in case
Ok, I will try again
I go back
thanks.
  Mondeo 2.2 tdci cold cant go above 3000 rpm Tancho 2 78 08-10-2017 04:54 AM
Last Post: @batterypack@
  Ford Ranger autonp 1 128 07-27-2017 04:09 AM
Last Post: nsw2790
Subaru Ford ranger used valve body replacement mkwila 1 117 07-24-2017 11:44 PM
Last Post: nsw2790
  Ford Focus 1,8 TDCI 115 PS P1211 and P0251 please help rosi1000rr 2 213 07-02-2017 08:47 PM
Last Post: Dzltec
  Egr off ford Ranger edc16 ninolino 3 186 06-06-2017 01:00 PM
Last Post: ninolino
  Help to start Focus 1.6 TDCI 2016 after the crash MKS_1 2 162 06-01-2017 12:51 AM
Last Post: MKS_1
Ford P2458 on 1.6 TDCi Engine after reprogramming ECU nebulein 3 214 05-31-2017 09:51 AM
Last Post: nebulein
  Ford Focus TDCI 1.8 F9DA injector coding via CDP+ euromod 3 1,050 05-12-2017 08:21 PM
Last Post: geneluauto
Ford P062B Ford Ranger remapsolutions 0 256 05-08-2017 09:04 PM
Last Post: remapsolutions
  Help ford Mondeo 2,0 TDCI flashing glow plug lamp rosi1000rr 13 367 04-20-2017 10:11 PM
Last Post: rosi1000rr
