  • 2 Votes - 3.5 Average
Re-Programming Attempt of the VGS
10-17-2017, 04:25 PM
Mercedes Benz Re-Programming Attempt of the VGS
Hi Folks, would like to ask for a little help.
Working on a 2009 E350 211.056 car
I was trying to reprogram the Transmission control module in the hopes to solve
my returning fault code " VGS defective ". [first screenshot]
In the process I ran into this hurdle.... [second screenshot]
The transmission has only one forward gear and Reverse. Not getting anywhere fast!
Is there a calculator available to fill in the missing data in the second screenshot ???
Would someone put it up for download.
Thanks a lot for the help, Albert.
10-17-2017, 05:12 PM
RE: Re-Programming Attempt of the VGS
What version of Xentry? Are you doing online programming and SCN coding?
10-17-2017, 07:29 PM
We can help. If you need online coding.
My Skype: Googly007
Mercedes SCN Coding & Retrofit
NTG Command Anti thief Code+SRS OFF and more.
10-17-2017, 07:31 PM
when you have this fault code Y38n4 control unit defective, does it not mean ecu needs to be replaced first ??
10-17-2017, 07:32 PM (This post was last modified: 10-17-2017 07:33 PM by danrad.)
Yes. You must first change then we can assist with coding.
My Skype: Googly007
 Thanks given by: KriyenKPp
10-18-2017, 06:10 AM
Mercedes Benz RE: Re-Programming Attempt of the VGS
(10-17-2017 05:12 PM)MBENZTECH Wrote:  What version of Xentry? Are you doing online programming and SCN coding?
I'm using XDOS 9_2016 Offline Programming.
I was trying to NOT to buy a new control unit, maybe just reload the software, with the existing parameters that are already stored in this module, that said without SCN.
Is that possible ?
Albert...
10-18-2017, 08:34 AM
Is that possible ?
Albert...
reflash current sw, coding usually stays the same, but I'd remember 4 digits in scn coding in vediamo
10-18-2017, 08:38 AM
Is that possible ?
Albert...
Try do this with using Vediamo or DTS Monaco
10-18-2017, 03:35 PM
I suspect you will end up replacing the control unit. I just did one. Mercedes supplied a rebuilt unit that was less expensive than I thought it would be. If you do replace the control unit, Xentry will give you a couple of options to program the new unit. You need to let Xentry suck the information out of the old control unit; then, plug in the new unit and program it. Xentry walks you through the procedure. If you just program the replacement control module the transmission will never shift perfect. There will be harsh shifts that will never adapt to satisfaction. If you can't read the defective control unit, Mercedes wants you to replace the entire valve body. Good luck.
 Thanks given by: KriyenKPp , JarsaR
  MERCEDES W204 VGS 0009021807 CFF FILE pitstop0212 3 635 07-11-2018 09:24 AM
Last Post: MECA TRANSMISSION
  VGS offline (Vediamo) programming video (China) paradise_garage 0 399 05-22-2018 08:20 AM
Last Post: paradise_garage
  w209 VGS fails programming EASatlanta 5 564 03-16-2018 10:40 AM
Last Post: EASatlanta
  CLA VGS FDCT 724.002 phara0n 4 321 03-16-2018 02:42 AM
Last Post: Jake5555
Mercedes Benz VGS 4 Renew DBMartin 1 359 02-06-2018 02:48 AM
Last Post: sixcode
