  • 1 Votes - 1 Average
Remove DTC of mercedes CLK
10-21-2017, 10:13 PM
Mercedes Benz Remove DTC of mercedes CLK
Hi!
Can anyone help me overwhelm these DTCs on a SIM4 of a mercedes clk 320 kompressor w208 in 2002?
With obd gemerico me from these:
P0101
P0302
While with bosch esitronic from these:
28 failure detection of cylinder ignition 1
11 mass air meter with hot fikm comparison not in order
27 loss of blows damaging the catalyst
cylinder 2
Thanks Marco.
Attached File(s)
sim4le.rar
File Type: .rar
Downloaded: 7 times
10-21-2017, 10:22 PM
RE: Remove DTC of mercedes CLK
(10-21-2017 10:13 PM)marchino79 Wrote:  Hi!
P0101
P0302
cylinder 2
Thanks Marco.
First
about the engine
32 compressor or 320?
Second
I have a w208 320 and changed already the air mass sensor once.
Quite common probLem when I have done a research. You may clean it but the problem will come back quite fast.
Third
Check the sparks, too.
Best regards
Jake
 Thanks given by: marchino79
10-21-2017, 10:44 PM
I would just remove the DTC, because the machine works fine, the mechanic has already cleaned the sensor and everything is ok ...
I just want to remove the dtc to turn off the engine light.
the mercedes is a 320 ...
Thanks marco.
10-22-2017, 05:19 AM
If everything is fine with your car, just clear the DTC with your tools. Just click of clear fault button.
10-22-2017, 05:22 AM
I know that, but I just need to remove them from the ECU so they do not see them anymore ...
  2002 clk 230 immobiliser problem Crane Pete 1 241 06-15-2018 02:45 AM
Last Post: MC-CYH
Mercedes Benz SIM4LKE MERCEDES KOMPRESSOR W171 DTC OFF talleres mcqueen 0 191 06-13-2018 03:13 AM
Last Post: talleres mcqueen
  Mercedes clk w208 need actual value for convertible shmuk 2 233 04-19-2018 05:24 AM
Last Post: shmuk
Mercedes Benz mercedes b class dtc off vkamuyu 1 478 03-07-2018 10:37 PM
Last Post: vkamuyu
  MERCEDES W245 REMOVE DTC pitstop0212 1 353 03-06-2018 02:04 PM
Last Post: nusa1979
