  • 2 Votes - 3 Average
Renault EDC16CP33 problem
01-11-2017, 07:25 AM
Renult Renault EDC16CP33 problem
Hello
I've written a map file to a Renault Laguna 2007 2.0dci engine M9R760 with EDC16CP33 by MPPS and now it doesn't rev higher than 1500rpm
Had written back the ori file and it's the same
The injector codes were noted before everything and written in the ecu after, but without any luck
I get only one fault code, DF1069 - Glow Plug Configuration Incorrect
Glow plugs are ok !
Any ideas?!
01-11-2017, 07:39 AM
RE: Renault EDC16CP33 problem
those ECU`s is recommended to RW via bdm.
maybe you loosed injector , pump, etc coding.
you have a renault clip to try rewrite the injectors again?
(I`m not a specialist but I have a Renault 1.9 dci , EDC16C36 and I was warned NOT to RW this ECU over obd port due to the problems mentioned above...)
01-11-2017, 07:55 AM
injector coding is not OK !
go to Renault and make the coding ! than ok !
01-11-2017, 08:03 AM
from what google says I think you need can clip to recode injectors and glow plug configuration..
01-11-2017, 09:19 AM
Ok, tomorrow i try withcan clip
Nissan Nissan X-trail 2.0 Dci EDC16CP33 0281013874 need full BDM or eeprom performance_pl 2 180 01-09-2017 12:51 AM
Last Post: performance_pl
  Nissan Xtrail edc16cp33 FAP off. juanillo 3 289 08-31-2016 08:08 PM
Last Post: juanillo
  EDC16CP33 EGR OFF volvo85 5 996 08-13-2016 01:49 AM
Last Post: ugndz
  Nissan edc16cp33 dpf off lubomirblg 5 1,197 07-29-2016 05:52 AM
Last Post: dlinnuy0010
  SOLVED - Need Help Nissan X-Trail 2.0 Dci EDC16cp33 DPF Off mariusica_boy 6 1,477 07-12-2016 10:41 PM
Last Post: mike_service
Renult [SOLVED] EDC16CP33 Laguna 3 DPF-OFF bertus82 0 579 03-12-2016 06:39 AM
Last Post: bertus82
  EDC16cp33 Nissan dpf off matiz1611 3 865 12-22-2015 11:33 AM
Last Post: matiz1611
  DPF OFF edc16cp33 Help Please nice 3 856 05-26-2015 11:58 AM
Last Post: jambajump
  laguna edc16cp33 immo off jabran200 0 630 03-11-2015 10:28 AM
Last Post: jabran200
  Renault Megane Dci-2.0 Edc16cp33 Chri1911 10 6,138 01-09-2015 02:06 AM
Last Post: Kykv
