  • 5 Votes - 3.2 Average
Renault EDC16CP33 problem
01-11-2017, 07:25 AM
Renult Renault EDC16CP33 problem
Hello
I've written a map file to a Renault Laguna 2007 2.0dci engine M9R760 with EDC16CP33 by MPPS and now it doesn't rev higher than 1500rpm
Had written back the ori file and it's the same
The injector codes were noted before everything and written in the ecu after, but without any luck
I get only one fault code, DF1069 - Glow Plug Configuration Incorrect
Glow plugs are ok !
Any ideas?!
01-11-2017, 07:39 AM
RE: Renault EDC16CP33 problem
those ECU`s is recommended to RW via bdm.
maybe you loosed injector , pump, etc coding.
you have a renault clip to try rewrite the injectors again?
(I`m not a specialist but I have a Renault 1.9 dci , EDC16C36 and I was warned NOT to RW this ECU over obd port due to the problems mentioned above...)
01-11-2017, 07:55 AM
injector coding is not OK !
go to Renault and make the coding ! than ok !
01-11-2017, 08:03 AM
from what google says I think you need can clip to recode injectors and glow plug configuration..
01-11-2017, 09:19 AM
Ok, tomorrow i try withcan clip
  X-Trail 2.0DCI EDC16CP33 help please [email protected] 2 106 10-19-2017 04:59 AM
Last Post: vitkos
  need dpf off + sensors off nissan qashqai edc16cp33 shmuk 3 233 07-13-2017 01:23 PM
Last Post: Tim1313
  espace 4 2,0dci edc16cp33 dpf off diimon 5 309 07-11-2017 09:22 AM
Last Post: diimon
  X-Trail 2.0 DCI EDC16CP33 Lunacy 12 618 07-09-2017 11:45 AM
Last Post: Lunacy
Renult scenic 2 edc16cp33 dpf off sofix 2 248 06-28-2017 02:03 AM
Last Post: VR-6
Renult Renault Laguna 2.0dci edc16cp33 EGR OFF marchewa 2 198 06-22-2017 07:36 AM
Last Post: builes13
  Nissan Qashqai 2.0 DCI 150 CV EDC16CP33 DPF OFF abbassi.diag 4 248 06-19-2017 08:08 AM
Last Post: abbassi.diag
  Renault Espace IV 2006 edc16cp33 dpf off ars1 3 351 05-24-2017 12:08 PM
Last Post: CrankshaftPower
  laguna edc16cp33 dpf off testtuner 5 418 05-18-2017 12:06 AM
Last Post: testtuner
Nissan Nissan X-trail 2.0 Dci EDC16CP33 0281013874 need full BDM or eeprom performance_pl 2 677 01-09-2017 12:51 AM
Last Post: performance_pl
