  • 1 Votes - 5 Average
SD C4 Error (1.1)-1.501.9882.SDS2 after ~30 mins
10-18-2017, 02:21 AM (This post was last modified: 10-18-2017 02:26 AM by nqcj5n.)
Mercedes Benz SD C4 Error (1.1)-1.501.9882.SDS2 after ~30 mins
I just bought a Dell Latitude D830 + SDconnect C4. (with all the cables + green LAN-cable)
I only use the LAN-Cable, no Wi-Fi. The system works for 20-30 mins and then it throws the following error (accompanied with ticking relais inside the C4):
[Image: e2e720-1508325723.jpg]
System: XDOS Xentry Open Shell 03/2017
I think that it is a cheap china clone, but I am not sure.
Any ideas on how to fix this?
Thanks Smile
10-18-2017, 03:37 AM
RE: SD C4 Error (1.1)-1.501.9882.SDS2 after ~30 mins
That looks like a hardware error in the MUX.. run a self test and post the results.
 Thanks given by: Marcos , JarsaR
Mercedes Benz Xentry 03/2017 error code (2.99)-3.112 and then another error code [2221-32] khlui02 1 299 05-26-2018 07:09 AM
Last Post: Fouad
Mercedes Benz ABS error after replacement of Speed Sensor babijoe 21 1,952 04-15-2018 09:02 PM
Last Post: babijoe
  DAS fault (1.1)-1.501.9877 bulayooo 17 1,296 03-08-2018 01:50 PM
Last Post: bulayooo
Mercedes Benz Lane keep assist error after installed AMG cluster skull1 16 1,187 03-03-2018 04:40 AM
Last Post: sherwin1111
Mercedes Benz Help Xentry 12/2017 error (1.1)-1.501.9922. DAS mode taisuke-san 5 1,043 02-20-2018 09:10 AM
Last Post: bulayooo
