SD Connect C4 Selftest
01-14-2018, 04:24 AM
I have make a selftest with my sd connect clone and have two errors.
Who can tell me, whats the problem?
Attached File(s) Thumbnail(s)
Press the Thanks and + If I really Help YouFing32
01-14-2018, 06:33 AM
RE: SD Connect C4 Selftest
(01-14-2018 04:24 AM)sascha965 Wrote:  Hello,
Nothing to worry. Is it working good?
 Thanks given by: pesona , sascha965
01-14-2018, 06:50 AM
Yes, it is working good. Can you still explain to me what the mistakes mean?
01-14-2018, 07:05 AM
(01-14-2018 06:50 AM)sascha965 Wrote:  Yes, it is working good. Can you still explain to me what the mistakes mean?
Some of those tests need a special adapter to be tested. From the tests list you chose a very detailed one. Without that adapter those tests will fail.
 Thanks given by: DBmhh , pesona , ParisCY , sascha965 , JarsaR
01-14-2018, 07:40 AM
As long as it works without problems you can ignore it
If I have helped you please do not forget Thanks + Reputation Give5
 Thanks given by: sascha965
01-14-2018, 07:57 AM
Thanks all,
i will ignore it.
ps: i tested also with spezial adapter
01-14-2018, 07:58 AM
Instead of ignoring those errors I think it would be better to run the test without a test adapter, assuming you do not have one.
Now the mux is assuming certain pins on the diagnosis cable connector being looped and reports a failure obviously if you do not have the correct pins looped.
 Thanks given by: Marcos , pesona , sascha965
01-14-2018, 08:30 AM
I have tested without adapter and no mistakes. So long it works.
Thanks all
01-14-2018, 11:22 PM
(01-14-2018 08:30 AM)sascha965 Wrote:  I have tested without adapter and no mistakes. So long it works.
Thanks all
Now that's look as proper test result, Wink
watch on that serial number, there are roumors that it is on "black list" now. Sadsmile
Regards! Drive
Mercedes Benz help me connect SD Connect 4 with lan cable kentrinite 13 865 07-15-2018 06:59 AM
Last Post: LORD
Mercedes Benz W211 Audio 20->NTG 2.5, programmable with SD Connect C4? paalw 6 520 06-28-2018 09:38 PM
Last Post: michael130509
Mercedes Benz sd connect toolkit problem tomsku 3 435 06-27-2018 09:33 AM
Last Post: tomsku
Mercedes Benz SD connect error Shawnp 7 750 06-26-2018 11:40 PM
Last Post: Bartekj
Mercedes Benz SD connect c4 error MB-User 9 4,484 06-23-2018 11:25 AM
Last Post: Bartekj
