  • 1 Votes - 1 Average
SPRINTER W906 CRD3.20 ECU PROBLEM !
07-12-2018, 05:45 AM
Hello members i have problem with sprinter 906 2.2cdi 120kw . 651 engine .
The car does not start and i get a lot of fault codes on the ecu. In the attachment is the photo of the fault codes . I checked all the fuses and the relays are OK .
On the sensors i do NOT get 5V from the ecu . Can the ecu be a problem ?
Thank you .
Attached File(s) Thumbnail(s)
07-12-2018, 05:56 AM
RE: SPRINTER W906 CRD3.20 ECU PROBLEM !
1. Try to disconnect all sensors connected to 5V bus, 1 by 1.
2. Check wiring short to ground with ECU connectors disconnected.
3. Check power and ground to ECU.
Only after all those steps performed you can say your ECU is the cause.
07-12-2018, 05:57 AM
did you check wire in ecu
If I helped don't forget Thanks + Reputation Wink
07-12-2018, 06:32 AM (This post was last modified: 07-12-2018 06:39 AM by service.feratre.)
i disconected the big connector from the ecu and i measured direct pins from ecu for 5 v output from mas air flow sensor direct to ecu pins and i dont get 5V
(07-12-2018 05:56 AM)serg215 Wrote:  1. Try to disconnect all sensors connected to 5V bus, 1 by 1.
i disconected 1by 1 all sensors and still dont get 5 v from ecu. i messured direct from ecu pins for mas air flow sensor i dont get 5 v output from ecu
07-12-2018, 09:04 AM
check all fuse sam
Mercedes Benz MB Sprinter w906 315cdi - cruise control activation M_Kuzev 12 12,102 07-13-2018 12:20 AM
Last Post: Dublover
  reset ecu CLA 220D delphi crd3.E1 valkyr1e 5 402 06-29-2018 02:27 AM
Last Post: tirex2k
  Sprinter 906 2.2cdi 150HP SAM module problem HELP krzysdro 2 213 06-21-2018 05:58 AM
Last Post: krzysdro
Mercedes Benz Vediamo on Sprinter 906 with Delphi ECU graphix 6 1,885 06-04-2018 09:48 PM
Last Post: efka
Mercedes Benz 2015 Sprinter W906 Backup Camera Activation vtl1192 10 1,754 06-01-2018 01:08 AM
Last Post: kovacsg22
