Siemens SID803 Read flash problem please Help
08-20-2017, 05:39 AM
Hello
I need to read the flash from SID 803 ECU
I already try to read it with Ktag and FGtech to BDM but without success !
Please help with any solution
Thanks in advance
If you like my post and it helped you please press THANKS and +1 Reputation !Smile
08-20-2017, 05:41 AM (This post was last modified: 08-20-2017 05:44 AM by @[email protected].)
RE: Siemens SID803 Read flash problem please Help
post picture of your setup , bdm and connections , l always use 13.8 v
 Thanks given by: rosi1000rr
08-20-2017, 05:45 AM (This post was last modified: 08-20-2017 05:45 AM by danielgatan.)
make connection like this ...i have read with galletto
Attached File(s) Thumbnail(s)
08-21-2017, 10:11 AM
Soldering is the best way to fuc*up your ecu, always use bdm probes, no soldering required.
Post your connections for bdm (attention to pin1) and pin data to feed the ecu.
Regards.
Chiptuning services ,custom remaps, inmo off, egr , dpf, lambda, speed limits, dtc´s ,etc.
Worldwide assistance.
All brands, All vehicles, All files.
Fing32
08-21-2017, 10:15 AM (This post was last modified: 08-21-2017 10:17 AM by @[email protected].)
(08-20-2017 05:45 AM)danielgatan Wrote:  make connection like this ...i have read with galletto
wasnt this the connections for me9.7 ? no way l would risk that , did one today , its a simple job with bdm and there cheap m8 just order one
[Image: 500b141ea834749633aa71728dfb7389.jpg]
08-21-2017, 10:23 AM
No mate..its sid 803 ...read an write with galletto without problem..
Why do you think he's risky? to solder 5 wire!!
08-21-2017, 10:26 AM (This post was last modified: 08-21-2017 10:28 AM by @[email protected].)
l know its a sid803 but if you look at this they use them connection on me9.7 just in case you have wrong info http://mhhauto.com/Thread-Mercedes-ME9-7-reading-help saying that there the wrong colours , where do you get your info on them colours
08-21-2017, 10:28 AM
I already read it but the file is only 184 byte it s possible!?
08-21-2017, 10:30 AM
no m8 this is mine from today
[Image: 93097f239efee5e67184afd73f7a9a96.png]
Ford Focus sid803 DPF OFF good solution needed Architect31 1 82 Yesterday 04:45 AM
Last Post: Tuning-Full
Citroen c5 Sid803 5WS40199D-T bdm all file centrohifi 1 52 09-13-2017 09:39 PM
Last Post: centrohifi
Volvo SID803 VOLVO EGR cris 0 105 09-11-2017 01:38 PM
Last Post: cris
  SID803 configuration problem igorir 0 77 09-08-2017 05:13 AM
Last Post: igorir
VW SIEMENS 5WP4448 03 IMMO off HELP esad.zilkic 3 215 09-07-2017 10:42 PM
Last Post: kozik20l
  SIEMENS SIRIUS 34 IMMO OFF HELP. Pro.chiptuning 8 354 09-07-2017 11:21 AM
Last Post: mastaro
  Flash am29bdd160gb vs Flash s29cd016g teefyg1 0 87 09-06-2017 03:10 PM
Last Post: teefyg1
  Ktag siemens egs 53 reading problem Tunc Onder 0 123 09-04-2017 10:03 PM
Last Post: Tunc Onder
Peugeot Siemens TA 2000 ?? need help my-auto 3 143 08-29-2017 01:50 AM
Last Post: sixcode
  PSA Simens sid803 dpf off rakinik 5 414 08-29-2017 12:25 AM
Last Post: zurek40
