  • 1 Votes - 2 Average
Smart 451 problem with R in manual transmission.
10-21-2017, 10:19 PM
Hello.
Sometimes my mum's Smart make joke and do not want to apply R gear whtn shows it on odo. Only way is to try change for R many times or push the car Sadsmile
No fault codes... Any ideas?
If I helped you give positive REPUTATION by clicking [Image: postbit_reputation.gif]
10-22-2017, 04:20 AM
RE: Smart 451 problem with R in manual transmission.
(10-21-2017 10:19 PM)elwis272 Wrote:  Hello.
You need upgrade software in gearbox ecu.
 Thanks given by: sam13 , drcko
10-22-2017, 07:19 AM
NO....you need change clutch....i have same problem, try update software, calibrate without solve problem....i change new clutch and now is ok
If i helped click thanks and add reputationWink
 Thanks given by: Mercerwin
10-22-2017, 09:41 AM
I tried new adaptations and it helps for few days, problem come backs still.
I do not want to think about engine and gearbox romoval Smile but it's only way.
10-22-2017, 10:56 AM
Check the Brake light Switch!
[Image: Motor_logo21.png]
10-22-2017, 11:08 AM
Yes you need upgrade software in gearbox ecu. I had the same problem, after the update everything worked properly Wink
10-22-2017, 11:23 AM
I'm not sure but Brake light Switch could be changed. Thx for ideas! But which repair soluton is correct? I do not have vediamo so also will be problem for me, switch I will check in that week.
When cluster will be damaged the problems could be also on other gears??
10-26-2017, 12:52 AM
Sorry for my English!!!
You have to move your Clutch releaser forward. Just only 3 mm.
That it!.
Do it first. Nothing else first. Then try to drive 5 km.
Please give feedback.
Regards
 Thanks given by: Roberto , Mercerwin , antonio.giosuele
10-26-2017, 12:55 AM
(10-26-2017 12:52 AM)Mastag Wrote:  Sorry for my English!!!
That it!.
Regards
Drive direction or opposite? please be precise Kolo
  help smart 451 steering assist programming shmuk 5 342 Today 12:26 PM
Last Post: askoldkuznetsov
Mercedes Benz MB A Class CVT transmission problems **SOLVED** Msmax 40 67,046 02-16-2018 08:31 PM
Last Post: julespatch
  Smart 451 adjustment speedometer to 200km/h zioweb 9 1,212 02-11-2018 11:08 PM
Last Post: zioweb
  722.6(EGS) transmission code check alexjx 10 483 02-10-2018 10:53 PM
Last Post: alexjx
  Smart 451 changing vin on used instrument cluster jabran200 6 329 02-03-2018 02:10 PM
Last Post: jabran200
