  • 22 Votes - 2.59 Average
Software to read fault codes on mack trucks
09-04-2013, 05:24 PM
Hi everyone im looking for a software to diagnostic a mack truck i have ptt and vmack but none of them connect to the truck i try with a usb link and now i have a dearn born 5 protocol adapter is there any other software to diagnostic fault codes for mack that i can download please and regards
09-10-2013, 06:57 PM
RE: Software to read fault codes on mack trucks
If you only want to read the codes with an alternative program, try "insite fault viewer"
11-06-2013, 04:43 PM
What Mack engine are you trying to connect to? PTT should connect to nearly all of them. So far the only one I have had problems with is the ASET engines. For some reason, I can't get PTT to connect with either the NoRegon, Nexiq, Dearborn, or Mack white face adapter. I'm told that you have to have a orange colored adapter and others saying you have to do the connection manually.
On the PTT program, did you set the program to work with the adapter you have? If you didn't do that, you won't be able to connect to anything. Also, you need to update the software as well.
Support MHH Auto!!!
I always give thanks and reputation!
  Volvo Trucks Programming Issue with chassis num patroklou 14 1,073 11-18-2017 03:33 PM
Last Post: hanuzul
  MBE4000 Unit Pump Cal Codes? One Source Diesel 2 219 11-17-2017 04:58 PM
Last Post: Donald J Trump
  HELP NEW HOLLAND TF 78 ELECTRA PLUS ERROR CODES abunahwi 1 86 11-17-2017 12:57 PM
Last Post: cg10
  ELECTRICAL DIAGRAM AND CONNECTORS FOR MACK TRUCKS sierra1290 5 980 11-16-2017 09:23 PM
Last Post: joemama
AA+MHH TEXA IDC5 Trucks v42 ParisCY 0 142 11-14-2017 11:09 AM
Last Post: ParisCY
  Mack MP7 leadfeet1 4 451 11-11-2017 05:58 PM
Last Post: Common-Rail
  1997 Mack perimeter Change(help) mar1waldner 3 217 11-11-2017 12:09 PM
Last Post: goatz
  need mack help bennett22 11 277 11-11-2017 11:47 AM
Last Post: goatz
  PTT - Latest APCI Plus Data for UD Trucks SanzR 1 390 11-10-2017 09:59 AM
Last Post: angelscry
AA+john-deere-utility-mat+(7) Caterpillar Warehouse Forklift Trucks [01.2016] tasgroup 5 1,272 11-08-2017 02:06 PM
Last Post: dauvin
