  • 17 Votes - 3.41 Average
Strange DCDI_eErrorCode=204 with C4 clone, never had this
01-15-2015, 08:57 AM (This post was last modified: 01-15-2015 09:03 AM by hundling.)
Mercedes Benz Strange DCDI_eErrorCode=204 with C4 clone, never had this
i have an error with a C4 clone mux. There are symbols on the mux i've never seen like this.
The error appeard "over night", yesterday everything still worked fine.
Attached Screenshots, self test of sd connect says DCDI_eErrorCode=204 (204) error. I found another thread on the forum which says this error means i need to put batteries into the mux. But with batteries there is the same error. Is there a way to fix this?
Thanks for your help.
01-15-2015, 09:18 AM
RE: Strange DCDI_eErrorCode=204 with C4 clone, never had this
Check IP Setting at your Network Connection..
Already Correct or not ?
[Image: newsign.gif]
01-15-2015, 10:13 AM
The IP settings are ok. I forgot to mention that it isn't possible anymore to use wireless connection on the mux. The only options I have on the mux is "restart" or "delete configuration", I tried to delete the config but this hasn't changed anything.
01-15-2015, 04:21 PM
Most likely your C4 firmware is corrupted. You need to manually update it.
To do that you need to put good battery then delete configuration using the c4 and then do the update.
I had the same problem and that's how I fixed it.
 Thanks given by: DBmhh , Rocinante , hundling , JarsaR
01-15-2015, 11:25 PM
Thanks. Where can I find the right firmware for my device, don't want to brick it.
01-15-2015, 11:30 PM
(01-15-2015 11:25 PM)hundling Wrote:  Thanks. Where can I find the right firmware for my device, don't want to brick it.
Which DAS/Xentry release do you have? Have you checked if you have removed/renamed folders at the toolkit folder, containing the necessary files for your mux.
 Thanks given by: Rocinante
01-15-2015, 11:47 PM
I have 07/2014, I renamed these three folders in the toolkit folder to prevent autoupdates of the mux.
01-16-2015, 12:19 AM
(01-15-2015 11:47 PM)hundling Wrote:  I have 07/2014, I renamed these three folders in the toolkit folder to prevent autoupdates of the mux.
Good. Now create original folders without content. Then copy the three necessary files from your renamed folders to the update_manual folder and update your mux. Follow webmaster's instructions (should find them from the DAS/Xentry help thread).
 Thanks given by: Rocinante , hundling
01-17-2015, 06:34 AM
Thanks for your help. Works again after the manual update.
  Strange noise inside engine M271.820 tirex2k 34 1,378 06-24-2018 01:01 AM
Last Post: tirex2k
  W204 C-Class 204.046 tsimplas007 5 2,712 04-23-2018 11:35 AM
Last Post: tirex2k
  204 COMAND pin number please Rocinante 3 542 04-23-2018 07:39 AM
Last Post: Rocinante
  Mercedes S221 parking sensors strange problem shmuk 8 558 04-19-2018 03:31 AM
Mercedes Benz Mercedes W 204 Change to AMG Software cromacak84 3 557 04-18-2018 12:00 AM
Last Post: rabaukee
