  • 10 Votes - 2.5 Average
TecDoc Catalog 5xDVD (4Q/2012) Multilanguage / Multi-Uploads
10-06-2012, 05:39 AM
Post: #10
RE: TecDoc Catalog 5xDVD (4Q/2012) Multilanguage / Multi-Uploads
(10-04-2012 07:27 AM)Danilko Wrote:
(10-04-2012 05:00 AM)Mythika Wrote:  Hi again ^^.
I have installed it and seems it works, but could you tell me if I did all right?
Because I see in your picture date around 1900 and mine its until 2015.
EDIT: And about TD, why I see it still in grey? How it works? I SOLVED IT, it works perfectly but I clicked on wrong tab Blush
Thanks a lot and sorry for my English.
Hi
Your Screen - is NOT ENGLISH, but I'm think, that you don't apply the 2nd patch (Patch.Enable-UnLock.Technical.Data)... see in the same archive!
Don't worry, it works perfectly!! I clicked on wrong tab first time ^^.
10-07-2012, 11:47 PM
Post: #11
Downloaded and install...All works fine with only first new crack...Is it necesery to install the second crack too?
10-11-2012, 01:07 AM (This post was last modified: 10-11-2012 01:08 AM by Danilko.)
Post: #12
(10-07-2012 11:47 PM)lallasgr Wrote:  Downloaded and install...All works fine with only first new crack...Is it necesery to install the second crack too?
Apply only 1 crack!!! (if you need TD, apply approp. patch (Patch.Enable-UnLock.Technical.Data) also)
 Thanks given by: lallasgr
10-22-2012, 02:41 AM
Post: #13
AA TecDoc RE: TecDoc Catalog 5xDVD (4Q/2012) Multilanguage / Multi-Uploads
(10-03-2012 04:46 AM)Danilko Wrote:  [Image: tecdoc20124logo500.jpg]
TecDoc Catalog Multilanguage 5xDVD (4Q/2012) | 30,7 GB
The TecDoc Catalog (4Q/2012) is a flexible information systems, which allows you several personal settings to ease your daily work. TecDoc supplies the free vehicle spare parts market with current and comprehensive data for identifying and ordering parts – for both, PC as well as CV – directly from the databases of the cooperating automotive aftermarket manufacturers in a standardised catalogue form. You are only a few clicks away from the right part! Accurate identification of the right spare part! Quick customer service thanks to reliable part identification!
TecDoc Catalog is an electronic parts catalogues from standardised data records original data of parts manufacturers on DVD
* more than 2,892,000 articles
* over 1,500,000 illustrations
* more than 45,000 PC types
* 36,000 real existing CV types
* with technical additional information
* updated every 3 months
* multilanguage: 23 languages
The Information System TecDoc is the information source for the vehicle repair market with the original data of the parts manufacturers. Founded in 1994 by companies of the automotive aftermarket industry and the German Association for Spare parts (GVA), TecDoc Informations System GmbH has established itself as the leading supplier of electronic spare parts information on the European market.
Data search can be filtered by the following criteria (from the TecDoc manual):
1. General:
- Engine Code: the engine code
- Engine Type: then engine type
2. by Model Year (from/to):
- the engine was/is constructed during this period
- Engine Number: the engine number as defined by TecDoc
3. by Technical Data:
- Output in kW: engine output in kW
- Output in HP: engine output in HP
- Capacity (technical): engine capacity in technical terms
- Cylinder: number of cylinders
- Valves: number of valves
- Torque in Nm: the maximum torque
- Compression: the engine compression
- Bore: engine cylinder bore
- Stroke: piston stroke of the engine
- Main Bearings: the number of crankshaft main bearings
- Engine Block Design: the engine block design, i.e. straight or V
- Fuel Type: the required fuel type
- Charging: the type of charging, i.e. turbo- or supercharger
- Cylinder Head Design: the cylinder head design, i.e. OHC or OHV
- Engine Control: the type of engine control, i.e. timing belt or chain
- Valve Control: the type of valve control
- Cooling Type: the type of engine cooling, i.e. water or air
Program Name: TecDoc (4Q/2012)
Program Type: Electronic Catalog
Release: 2012
Version: 4Q2012
Developer: Parts Info LLC
Homepage: http://www.tecdoc.de
Interface Language: Multilingual
Platform/OS: Windows 2000/XP/vista/win7
Crack/SN: Present (TXT-Manual & Patches 2012)
File Format: .Nrg (5xDVD)
File Size: 30,7 GB
Quote:Install notes: The treatment procedure steps described in TXT-files in the archives with a Patches! When installing on Win 7 (only if the program does not start!) In the properties of a shortcut on the desktop - to set the "compatibility with XP.SP3"
Add. Info: In the archive "0.New_TecDoc.2012_Crack_worked.to.2015Y+Patch.Enable-UnLock.Technical.Data.rar": Crack, worked to 2015Y + Patch, for Enable/UnLock Technical Data.
- Alternatively, you can use medicine from the archive "0.Old_TecDoc.2012_Final.Crack+Patch_v2.rar".
[Image: 137b9e7908c9ba1fb78580bdce384fd5.jpeg] [Image: 83a2a4e6b4c19dc579f9515acb0efda1.jpeg] [Image: 8a1c975721bf4d2f54c04d45b3e35610.jpeg] [Image: 5c46a62d8a08b8413b41002c8f646bd1.jpeg]
Hello everyone, can you tell me how could I make a search in Tecdoc by chasis number, which option I need to choose??? Is this possible? thanks in advance
10-24-2012, 01:35 AM
Post: #14
Free Tecdoc online catalogue ....
1-)http://www.repxpert.com
2-)register free now
3-)repxpert catalogue=powered by tecdoc
4-)open repxpert catalogue
good luck
 Thanks given by: sanjin2003
12-12-2012, 10:51 PM
Post: #15
I downloaded the following data to use the "TecDoc 4Q2012".
1: New_TecDoc.2012_Crack_worked.to.2015Y + Patch.Enable-UnLock.Technical.Data
2: Old_TecDoc.2012_Final.Crack + Patch_v2
I used the data of No.1. Is it reasonable that it should use the "TecDoc old" is No.2? No.1 in the data have the following files.
1: NEW + GOOD.Only.Crack_TecDoc.2012
2: Crack_worked.to.2015Y
3: Patch_TecDoc.Enable-UnLock.Technical.Data
What is the difference between the No.2 and No.1? I I do not know.
It is just possible activation No.1. I want to know why you use a No.2.
Thank you.
  BMW ETK 05/2017 (MULTI) Tulex 2 169 05-25-2017 12:04 AM
Last Post: MuDvAyNe
  Multi purpose software for scanning codes and dignostics 379cat 5 208 05-23-2017 09:03 AM
Last Post: 379cat
Renult Renault CAN Clip V167 (MULTI) Tulex 1 427 05-16-2017 03:37 AM
Last Post: didi_du_93000
  Looking for Crack TecDoc Q2 2016 BadBoy! 1 208 05-05-2017 05:36 AM
Last Post: Sev17teen
AA TecDoc TecDoc CATALOG [4Q.2016] Full Multilingual megashared 12 4,470 04-30-2017 11:25 AM
Last Post: nimametal
  multi-diag I-2015 interface error need help please hilfiger03 4 152 04-26-2017 12:09 AM
Last Post: titoun
  Mercedes-Benz WIS/ASRA 04.2017 (MULTI) Tulex 0 390 04-25-2017 12:05 AM
Last Post: Tulex
Mercedes Benz Mercedes-Benz EPC 04.2017 (MULTI) Tulex 0 363 04-24-2017 11:59 PM
Last Post: Tulex
AA TecDoc TecDoc 2Q.2016 (Multilanguage 8x DVD's in 1 FOLDER) kalatopas 6 1,614 04-20-2017 05:11 AM
Last Post: glavanesti
AA+MHH TecDoc CATALOG [1Q.2017] Lite Multilingual megashared 1 1,750 04-07-2017 03:00 AM
Last Post: eskilo
