  • 5 Votes - 3 Average
Toyota Landcruiser 2001 BCM Location please?
08-12-2017, 09:02 PM
Toyota Toyota Landcruiser 2001 BCM Location please?
Hi Friends
Is BCM on Toyota Landcruiser 2001 Incorporated with the inside FUSEBOX? or separate? My alldata is bad I stuck with info please. This car's central door lock are not working, wippers are not working , interior lights are not working also. I saw a Small ECU (red) RECIEVER, DOOR LOCK CONTROL, replaced but nothing worked Though someone said I need to program it first. PLEASE I JUST NEED AN URGENT HELP ON THIS.\
I'll be grateful
08-12-2017, 09:35 PM
RE: Toyota Landcruiser 2001 BCM Location please?
Right in Passanger side behind fascia 1min dissasembly
 Thanks given by: DANITO
08-12-2017, 09:42 PM
(08-12-2017 09:35 PM)cardiagnostic Wrote:  Right in Passanger side behind fascia 1min dissasembly
Please how does it look like? black? any part no. suggestion so that I can check it online now. I've google with bcm, multiplex unit terms but could not find any thing helpful.
THANKS AND REP AWAITS YOU AGAIN
08-15-2017, 06:02 PM
If by BCM you mean Body control module try searching main Body ECU. Main body usually incorporates fuses, and relays. Most commonly located under drivers side dash (left for US). It may be on right side for Non US vehicles
Toyota Cannot find Toyota IQ 1.4D4d 90hp ECM location vicfurpac 2 128 07-03-2017 12:25 PM
Last Post: vicfurpac
Toyota Toyota Tarago (Previa) 2001 ACR30 OBD2 wiring astroboypaul 2 225 01-28-2017 06:05 PM
Last Post: paddyman
  2001 Honda Accord pcm replacement nymike 4 894 10-25-2016 12:27 PM
Last Post: narkeleptk
Toyota TOYOTA HIGHLANDER 2001 used ECM Programming DANITO 2 474 02-29-2016 12:58 PM
Last Post: DANITO
  Help: need virgin immo 2001 4runner Deplore 0 389 12-30-2015 01:17 PM
Last Post: Deplore
Toyota AVALON 2002 EEPROM LOCATION DANITO 0 476 10-10-2015 09:18 AM
Last Post: DANITO
Toyota Best Toyota Diagnostic Software/Hardware for Caribbean Toyota sattv2000 4 1,831 07-19-2015 05:22 PM
Last Post: kamaleon
  someone with experience installing landcruiser 2013 dpf emulator? legendz 2 612 05-05-2015 04:19 PM
Last Post: legendz
Toyota any solution to the problem dpf filter toyota landcruiser diesel especially legendz 9 4,368 12-07-2014 10:33 PM
Last Post: bohosh
Toyota 2001-2006 Toyota Tacoma Factory Service Manuals gdagreat 0 771 02-23-2014 07:29 AM
Last Post: gdagreat
