  • 138 Votes - 3.12 Average
VCDS/VAG-COM REPAIR
03-26-2011, 11:06 PM
Post: #28
RE: VCDS/VAG-COM REPAIR
(03-24-2011 12:27 AM)haker112000 Wrote:  Zdravo
Kupio sam kineski klon 10.6 i kad ga prikopčam na auto , sve je uredu osim da uređaj nije priključen na auto. Reprogramirao sam Atmegu sa 908 verzijom ,FTDI takođe , ali GAL nisam jer neznam sa čim da ga programiram i izbaci mi istu grešku kao i sa verzijom 10.6 . Šta mi je radit ako može pomoć, može i na e-mail
Hello
I bought a Chinese clone 10.6 and when it attaches to the car, everything is fine except that the device is not connected to the car. I reprogrammed with Atmega 908 version, FTDI also GAL but not with anything because I do not know that it is programmed to throw me the same mistake as with version 10.6. What we are doing if you can help, can e-mail
And to mention that I removed the extra parts and bridge as the lines
is it ft232rl or ft232bl based 'cause if it's RL then you have worst possible hardware, somebody posted here solution for vcds with FT232RL, try that and if you don't succeed try to find interface with FT232BL
03-29-2011, 03:07 PM (This post was last modified: 03-29-2011 04:02 PM by digital4.)
Post: #29
Hello
What is the solution for non working RL interfaces...
Tried to find it on the forum without success...
Any links would be appreciated...
Thanks...
(03-11-2011 10:20 AM)nikoz Wrote:  I have this interface. Can you show me how to insert a 10.6 dump?
Ovo je moj interfejs. Mozes li Milko da mi pomognes da mu promenim damp? Hvala!!!
I see on these pictures that wires are disconnected from the PCB... All 4 wires must be soldered on PCB... Smile
(03-21-2011 11:24 AM)DjRomeo Wrote:  Hello ,again I tryed fix my problem alone but nothink :/
1.I install VCDS 10.6 to my computer (windows 7 X64 bit) ,but then I install complete i have error (in picture error).
2. I cant open VCDS after install I double click but nothink :/
3. In manager device all good ross-tech usb drivers show .
How fix this problem ? I want what my VCDS work 100% in my computer windows 7 x64 bite ,because I have very importants data.
Here I show pictures how you say.
You can download and install original VCDS from rosstech... version 10.6...
That will also install drivers for your x64 OS...
Then uninstall that version (drivers will stay on the computer) and then you can install version you received with your vcds, but do not install drivers in the end....
After this you can connect your cable to the usb port and OS will assign x64 drivers to your cable and you will have working VCDS...
Smile
03-30-2011, 05:52 PM
Post: #30
VW RE: VCDS/VAG-COM REPAIR
here have how to do .
Attached File(s)
VAG908 Driver for Windows7 x64 Installation Guide.rar
File Type: .rar
Downloaded: 783 times
 Thanks given by: Milko , webmaster , mfan , zipoman2011 , rabihfiras , bxin5 , Kenny , vwgolfvr61
04-01-2011, 06:13 AM
Post: #31
hello!
i need the newest vcds in german. i hve a cabel and will update it. thanks
 Thanks given by: baboiu_electric
04-02-2011, 09:12 AM
Post: #32
(04-01-2011 06:13 AM)zenek Wrote:  hello!
try this http://www.diagnosetool.de/runterladen/V...-setup.exe
 Thanks given by: webmaster , baboiu_electric
04-03-2011, 03:35 AM
Post: #33
Hi Milko,
Thanks for the 908 dumps that you posted. I`ll need a dump for romanian language, do have this ??
Best regards
04-04-2011, 05:02 AM
Post: #34
(04-03-2011 03:35 AM)marian Wrote:  Hi Milko,
Best regards
sorry no dumps for romanian language, only Bosnian,English and German
04-04-2011, 10:55 AM (This post was last modified: 04-04-2011 10:55 AM by quattro.)
Post: #35
Dear all,
does anyone of you have a dump from the Englisch VCDS 106 Interface?
Thank you for your quick response.
Rgds
Peter
04-07-2011, 11:11 PM
Post: #36
Best regards
Milko, do you have German dump for BL interface 908 version?
Thanx for your answer.
  VCDS 16.8.4 sledzik1984 0 212 07-03-2017 09:57 PM
Last Post: sledzik1984
  vcds not working (EU clon) Bagoni 6 343 06-16-2017 10:31 AM
Last Post: Bagoni
  VCDS 17.1.3 like original? miki1986 4 573 05-27-2017 05:04 AM
Last Post: baubau
  vcds problem godax 3 219 05-19-2017 11:37 AM
Last Post: sixcode
VW vcds obdeleven gordonasp 0 260 05-08-2017 08:57 PM
Last Post: gordonasp
  VCDS problem or car problem miki1986 1 250 04-24-2017 09:45 AM
Last Post: King91
VW Vcds interface not found ryn079 10 673 04-17-2017 10:32 AM
Last Post: @batterypack@
VW VCDS HQ clone moaz1233 1 562 03-09-2017 10:48 PM
Last Post: Amaa
Saab Can vcds 16.8.0 work with vcds 17.1 unlocker 1 652 03-08-2017 03:37 PM
Last Post: grainqey
  Clone VCDS 12.10.3 performance_pl 1 426 03-01-2017 10:16 AM
Last Post: marx232
