  • 138 Votes - 3.12 Average
VCDS/VAG-COM REPAIR
01-09-2013, 10:18 AM
Post: #352
RE: VCDS/VAG-COM REPAIR
Thanks m8, now that answered the question. Anyway lets hope this works so I don't have to dish out another 25$.
01-09-2013, 01:14 PM
Post: #353
(01-08-2013 11:48 PM)wysi Wrote:  First, try do display the possible codings, (click, or mark the value in the coding window), a yellow popup should display all the possible codings. (see picture in attachment)
I think, you have to calculate the coding value from the binary value.
1. save (just copy paste) your original code from device 17, coding -07, in a txt document. (so you can restore it, if you did a wrong coding)
2. convert it to binary (windows calculator, programmer mode) -> something like this: 14854 decimal to 011010111010011010 binary (not correct, just an example)
3. set the bit 0 in byte 1 to 1 -> that’s the 9th bit from right
4. convert it back to decimal
5. insert it in de vcds coding
6. test if coding works as expected, otherwise code de old saved value.
ok, will try that.
thank you m8
Fing32
01-10-2013, 05:26 AM (This post was last modified: 01-10-2013 05:27 AM by hadaak.)
Post: #354
Hi Guys,
happy new year to all :-)
I have a vcds 10.6.3 with an RL chip. I don't want to go into the hassle of the upgrade. i found this cable. Is it a good buy. I know it's cheap but it looks like the one I have which is working pretty good.
VAG COM 11.3 VCDS 11.3 with FT232BL and ATMEG162 Chip free shipping
http://www.aliexpress.com/store/product/...91585.html
Thanks.
01-10-2013, 06:33 AM
Post: #355
Hi
And you asking if someone have it and telling you that it is good or not, am I right?
Maybe you'll find someone who will said:'If I did it wrong choose why should other do it as me, with other words if someone loose money it is better for him to know that you loose too"
Well this is just of joke about ppl like you who ask someoneelse if it is ok to buy something or not.
Now never mind my joke, that tool it is very good but take care mate the one it is version11.3 ( in fact 11.2 but it is use a cracked vCDS 11.3 Beta version ( VCDS 10.6.3, then VCDS 10.6.4 then VCDS 11.2 and VCDS 11.3 )
So you don't do a great upgrade but as I told you the hardwear is very good. I have one of that tools and it is the best hardwear for a clone.
Good luck
01-10-2013, 08:57 AM (This post was last modified: 01-10-2013 10:50 AM by A6Power.)
Post: #356
any one have a dump for VCDS 10.6.4 and does the search function on this site work?
01-10-2013, 10:31 PM
Post: #357
(01-10-2013 08:57 AM)A6Power Wrote:  any one have a dump for VCDS 10.6.4 and does the search function on this site work?
the search function works bad: search "vcds" finds all vcds threads. search 11.11 finds no thread. But there are also threads named "vcds 11.11"
To find the dumps, read this thread from beginning!
English 10.6.4: http://mhhauto.com/Thread-VCDS-VAG-COM-R...6#pid16206
01-12-2013, 02:51 AM
Post: #358
(01-10-2013 06:33 AM)mattydr67 Wrote:  Hi
Good luck
OK. So you know where I can get a cheap clone with bl chip and vcds 11.11.3?
Thanks.
01-12-2013, 03:54 AM
Post: #359
I don't know where you can buy a cheap VCDS 11.11.3 with FT232BL sir
From what I know the VCDS 11.11.3 cheap clone from China are with FT232RL adn a very bad cracked softwear.
Even I knew this I will advise you to buy a cheap clone which can be erased and become unusable and then you post here how you can reflash it.
The good clone cost twice at least and cannot be erased.
Good luck
 Thanks given by: perotok
01-14-2013, 06:23 AM
Post: #360
hey guys,
can someone kindly tell me what pins to connect when using
the Atmega Fusebit Doctor in order to reset the pins.
thanks
  VCDS vs. VAS5054 ??? bersch8688 5 254 08-10-2017 10:31 PM
Last Post: diagnostix
  VCDS 16.8.4 sledzik1984 0 308 07-03-2017 09:57 PM
Last Post: sledzik1984
  vcds not working (EU clon) Bagoni 6 428 06-16-2017 10:31 AM
Last Post: Bagoni
  VCDS 17.1.3 like original? miki1986 4 712 05-27-2017 05:04 AM
Last Post: baubau
  vcds problem godax 3 258 05-19-2017 11:37 AM
Last Post: sixcode
VW vcds obdeleven gordonasp 0 306 05-08-2017 08:57 PM
Last Post: gordonasp
  VCDS problem or car problem miki1986 1 284 04-24-2017 09:45 AM
Last Post: King91
VW Vcds interface not found ryn079 10 776 04-17-2017 10:32 AM
Last Post: @batterypack@
VW VCDS HQ clone moaz1233 1 639 03-09-2017 10:48 PM
Last Post: Amaa
Saab Can vcds 16.8.0 work with vcds 17.1 unlocker 1 715 03-08-2017 03:37 PM
Last Post: grainqey
