  • 53 Votes - 3.06 Average
VCDS VAG-COM VAGCOM 12.12.0 12.12.1
03-20-2014, 02:01 AM
this is newest VCDS(VAG COM) Cable,with original Englsh & french software.Quality is good.i tested it well.this seller has English & French.
English Cable:http://www.aliexpress.com/store/group/VA...43224.html
French Cable:http://www.aliexpress.com/store/product/...78900.html
03-20-2014, 09:00 AM
RE: VCDS VAG-COM VAGCOM 12.12.0 12.12.1
You are the seller and it's usually not allowed to advertise here.
So before this gets deleted/moved I have a free tip for you.
Be honest with your customers and attach the PCB pictures to your ads (and of course then really send that out, not something else). That would make you stand a bit out of the sea of all the knockoff sellers.
I usually do and write stupid shit, but if I helped you please take a second and leave a positive rep and/or thanks.
 Thanks given by: mattydr67 , perotok , hartklep , paro44 , Svoboda
03-20-2014, 10:06 AM (This post was last modified: 03-20-2014 10:08 AM by mattydr67.)
Mate as you can see that tools as many of chinese version now has no GAL or ATF
This mean that no full functions coverage
As I saw all this new clones are the same as this one
What do you think about this two HQ clones made in China too Mr.chishengobd?
This one are preatty much as the genuine one adn full functions
And there's also other hardwears with full chips
Good luck
VCDS_1.rar
File Type: .rar
Downloaded: 1146 times
VCDS_2.rar
File Type: .rar
Downloaded: 900 times
 Thanks given by: perotok , Marcos , hartklep , hixpp02 , paro44 , mdanilo , erikredhead , BADRI , grpana , maxeugen1 , tomek1111 , samatii , Svoboda , DB77AAA , kokibom , nerminb
03-20-2014, 05:03 PM
(03-20-2014 10:06 AM)mattydr67 Wrote:  Mate as you can see that tools as many of chinese version now has no GAL or ATF
Good luck
no matter what you believe it or not.It is the truth.if you did not use it,pls do not judge it first!
03-20-2014, 06:51 PM
Mate maybe you do not know but this solution without GAL/ATF was made by one of my old mate in other forum 2 years ago
This solutions without GAL/ATF is not good only because you'll not have same coverage as the genuine tool and mesuring blocks are incopleat
So please I do not need to test item because I tested all kind of tools released in China
The best hardwears made ever in China are tha one that I shared and one hardwear that it is not manufactured anymore ( for 3-4 years ago )
But I wish you good luck in your bussines
Good luck
 Thanks given by: paro44 , BADRI
03-20-2014, 10:54 PM
There is VCDS 12.12 with original chips available. So maybe that is reason why "we" can use genuine software?
Reworked + reprog. to 0475 Galletto/Kess/Ktag available!!!
 Thanks given by: chishengobd
03-21-2014, 02:03 AM
Original chips?????
Do you think that you buy original chips from China?
I don't think so
We do not talking about fact that you are able to run the softwear with a clone
If the clone have not all chips and original configuration ( schematic ) then you cannot have a good coverage
All tools ( chinese one ) with Atmega can be flashed to works with any versions of VCDS
This is not a problem
The problem is when you want to connect to some controlers or to do some functions that ned GAL/ATF
Anyway everyone may work with any tools he wants
But there's chinese hardwear for VCDS that are similar as the genuine but I haven't seen any of it using FTDI 232RQ
Maybe this is the answear you wanted to hear or not.
Be more specific if you want
Good luck
 Thanks given by: BADRI
03-22-2014, 12:43 AM
(03-21-2014 02:03 AM)mattydr67 Wrote:  Original chips?????
Yes, original. Not opened my tool yet to check out.
What controllers you mean, can you specific so i can check/test my tool is it like genuine or fake?
03-22-2014, 01:31 AM
All the tools are fakes (unless you bought them from Ross Tech). But there're more versions of the fake ones. Some without the GAL/ATF chip (which is bad), some with NEC chip instead of original atmega which is good (if I'm not mistaken mattrydr67 prefers those), then there are some with the FTDI BL/BM chips and some with FTDI RL chips (all the new ones are RL afaik) - the original has FTDI RQ chip (new ones, older ones had BM afaik). Then there're some that are easly accessible for flashing (the pins are accessible so you don't need to solder on the chip pins itself) some that're pured over with plastic/something like that (over the chip). And probably many more chinese knockoff versions out there.
AA+MHH VCDS/VAG-COM REPAIR Milko 1,448 1,046,172 Today 07:32 AM
Last Post: alexm1
VW VAGCOM KKL 409.1 PROBLEM strikeforce 2 81 02-19-2017 06:32 PM
Last Post: ZapDus
  Clone VCDS 12.10.3 performance_pl 0 88 02-19-2017 12:27 PM
Last Post: performance_pl
  Odd VCDS behaviour zit501 3 100 01-30-2017 06:40 AM
Last Post: @batterypack@
Audi VCDS : What's possible with good clones? dj2d 0 359 01-01-2017 11:55 PM
Last Post: dj2d
VW VCDS 16 Clone Aldi 6 830 12-14-2016 02:03 PM
Last Post: Aldi
VW Genuine VCDS license revoked Onotole 11 1,068 12-02-2016 11:42 AM
Last Post: Proxide
Porshe Porsche Diagnose tool like VCDS d3signz 6 407 11-22-2016 03:12 AM
Last Post: Hansdampf
VW HEX+CAN VCDS Pictures of original tool vwman 0 426 11-22-2016 02:02 AM
Last Post: vwman
  VCDS 15.7.1 Clone long coding Nikki 18 6,324 11-15-2016 09:07 AM
Last Post: ericas
