Volvo xc90 2006 immo off
10-23-2017, 11:33 PM
Volvo xc90 mfd 2006 engine D5, London rain in the electronics, what should i do to start the engine, where is immo stored ? Injection ecu should i change with an immo off one ? Car located in London, me in eastern europe, just a friend of mine wants to fix the Volvo i was asked for an advice ...!
10-23-2017, 11:39 PM
RE: Volvo xc90 2006 immo off
you need remove 1 - CEM read eeprom 2 - read ECM eeprom make synchronization and write back to ECM .
immo off not possible
 Thanks given by: alfabit
10-24-2017, 03:43 AM (This post was last modified: 10-24-2017 03:43 AM by alfabit.)
Ok, but we found on ebay various models of EDC for xc90 ( modi immo off ), if i buy an immo off ecu exactly the type ( possible EDC16 ) could the engine be started to get the car home ?
10-24-2017, 03:52 AM
(10-24-2017 03:43 AM)alfabit Wrote:  Ok, but we found on ebay various models of EDC for xc90 ( modi immo off ), if i buy an immo off ecu exactly the type ( possible EDC16 ) could the engine be started to get the car home ?
nope, i car will not start. CEM will not give feed to fuel pump and for lot of other sensors
10-24-2017, 06:39 AM
Not possible to disable immobilizer in these ECUs. If you are very lucky you will be able to just copy EEPROM and start the car. The problem is that there are so many different software versions and you need to find one that matches. Also take note that you can have the same HW-nr(both Bosch and Volvo) but different gearboxes so you also need to find one with same gearbox.
Good luck!
  Passat 3C 2006 2.0 TDI reset Immo Timer TIGRI007 8 250 11-13-2017 09:44 AM
Last Post: stabilo
  Ford Focus 2006 immo syncro Mirzaa 2 98 11-06-2017 09:05 AM
Last Post: Mirzaa
  immo off kia sportage 2006 ECU BOSCH 0 281 013 420 cyber30 5 150 10-13-2017 09:57 AM
Last Post: MANIEK90
Audi 2006 Audi A6 Immo off dmp_canada 9 229 10-02-2017 03:01 PM
Last Post: dmp_canada
  does not dash Volvo XC90 Panoramix 1 311 09-18-2017 03:32 AM
Last Post: tronf
VW Passat B6 1.9 TDI 2006 Key to immo match oktawian 13 420 09-09-2017 08:31 AM
Last Post: oktawian
Volvo Volvo xc90 Polish language werni21 2 549 08-27-2017 11:13 AM
Last Post: lucki
  immo off toyota yaris 2006 petrol denso julespatch 0 231 08-20-2017 05:11 PM
Last Post: julespatch
  2006 Toyota Yaris 1.5L Immo off help julespatch 1 172 08-18-2017 11:46 AM
Volvo please help i need file dash volvo xc90 javiercj 1 165 08-18-2017 01:06 AM
Last Post: gepakg
