  • 3 Votes - 2 Average
W163 ML270 CDI
10-16-2017, 11:56 PM
W163 ML270 CDI
Good day,
I need help. I have a big problem.
My Mercedes Benz ML270 CDI will not start. There is a ENGINE FAULT:
P1617 - EEPROM or incorrectly coded or N39/2 (CDI control module)
Please help me. I am knowledgeable in checking but can someone please guide me on what to look at. Thank you
Kind regards,
Bidong
10-17-2017, 12:38 AM
RE: W163 ML270 CDI
incorrect coding or coding is lost. U need to flash and code module online
 Thanks given by: Poptest , bidong
10-17-2017, 12:59 AM
RE: W163 ML270 CDI
(10-16-2017 11:56 PM)bidong Wrote:  Good day,
Kind regards,
Bidong
renew ecu and learning with star
 Thanks given by: bidong , JarsaR
10-17-2017, 04:52 AM
Mercedes Benz RE: W163 ML270 CDI
Kind regards,
Bidong
All depends on what happened to the appearance of this DTC?
DTC is the starting point for diagnosis, so you need to start with a reason!
Tuning -> write stock dump.
Other - try already wrote above.
10-17-2017, 05:11 PM
RE: W163 ML270 CDI
The original complaint was white smoke and rough idle.
It was still running when I installed my diagnostic tool. I tried to do the injector cut off using a scan tool because if you pull the injector harness from the injector socket, the engine chooses to die.
The injector cut off did not work with the vehicle. The next thing is that the vehicle now does not want to operate the starter and has the P1617 fault.
10-17-2017, 05:23 PM
RE: W163 ML270 CDI
(10-17-2017 12:38 AM)tirex2k Wrote:  incorrect coding or coding is lost. U need to flash and code module online
hello tirex2k....... I have a friend who has same P1617 problem. How do you do flashing online? Only Mercedes Benz can do this?
10-17-2017, 10:25 PM
RE: W163 ML270 CDI
u need to check if ur coding is lost, u may do it by checking coding string in vediamo. U can buy online access from danrad or other users, it doesnt cost much
 Thanks given by: Rocinante , Poptest , temo4ka
10-18-2017, 05:40 PM
RE: W163 ML270 CDI
Hello tirex2k, what can cause the coding to get lost or corrupted?
  W205 CDI SW update emuriuki 9 794 04-15-2018 08:11 PM
Last Post: emuriuki
  SMART 451 2013 CDI EURO5 ECU PINOUT DRWGS dg-power 1 263 04-14-2018 09:28 AM
Last Post: audiomeca
  HELP –Problems Programming TCU unit with vediamo Smart 451 CDI djscotch 0 254 04-08-2018 12:58 PM
Last Post: djscotch
  Ml 250 CDI problème rezak 0 152 04-03-2018 12:08 AM
Last Post: rezak
Mercedes Benz vito W639 CDI no start, no CAN signal in ECU from EZS laz79 13 983 03-28-2018 11:59 AM
Last Post: emuriuki
