W164 exhaust presure Sensor
12-11-2017, 12:55 PM
Mercedes Benz W164 exhaust presure Sensor
Hello ! I have a Problem with my w164 280cdi! Sometimes when I cold Start Mil Light comes and engine is shaking! Error Code is exhaust pressure Sensor Pressure to high! Turbo and outlet mufflers are new! Pressure Sensor is also New! Exhaust pressure is when engine is Not running at 4380hpa when running 4390 hpa! Cables are good!
Greets
12-11-2017, 02:23 PM
RE: W164 exhaust presure Sensor
Take a look at my thread, there's lots of info there:
http://mhhauto.com/Thread-W164-320-CDI-k...ure-sensor
Hit 'Thanks' and '+Rep' if I helped plzFing32
 Thanks given by: Rocinante
12-11-2017, 10:21 PM
Hello
such trouble are from two different reason:
1.can be from internal barometric sensor from ecu
2.can be from air quality sensor( left side air filter housing ) also this one are the second barometric sensor
to find which one are damage you have to do a small trick:
1.start engine and disconnect air quality sensor,barometric pressure must be 1020mBar and your car must have a good responce on test drive
2.start engine and disconnect back pressure sensor and the value must be 1920-1980 mBar ( depend of sw version)
In both cases the value can be "set" in file for a standard value and no more trouble if that vehicle are somewhere 20-30 meters above the sea level!
But if the owner must go with his car in the mount area at 1800-2000m above sea level that car will have a slow responce becouse barometic pressure will be under 980mBar and the differences should not be lower/higer than 50 mBar !
Full WinOLS User
Custom ENG/GER OLS file for TUNE/DPF/SCR/EGR/TVA/VSA/DTC and more...
www.quick-tuning..com
 Thanks given by: KriyenKPp , JarsaR , kodi366
12-12-2017, 02:51 AM
(12-11-2017 10:21 PM)mike_service Wrote:  Hello
So i let the Sensors disconnected? And only adjust with diagnosis or with ecu Software? Thank you
12-12-2017, 03:32 AM
Only with edited software/file ! also sensor can be connected !
Full WinOLS User
01-14-2018, 11:44 PM
hi, run control driven turbo compressor, excessive turbo pressure compressor the car presents problem on back pressure sensor.
Mercedes Benz NOx Sensor replacement MED40 ClkCabrioDriver 19 999 Today 12:21 AM
Last Post: trigital
Mercedes Benz 2006 sprinter door open sensor fault? Baja juan 0 86 07-18-2018 04:04 AM
Last Post: Baja juan
Mercedes Benz w205 c63 retrofited switchable exhaust from c63s jkiller1983 7 548 07-13-2018 08:15 PM
Last Post: minogun
Mercedes Benz MB w212 hood open sensor emulator Arm3 2 220 07-12-2018 09:03 AM
Last Post: Rocinante
Mercedes Benz MB ML W164 key wont turn after dead baterry kentrinite 4 469 07-12-2018 03:44 AM
Last Post: redangell
