  • 2 Votes - 1 Average
W166 - AdBlue problem
12-12-2017, 06:40 AM
Mercedes Benz W166 - AdBlue problem
I have this fault in AdBlue system. After clear it, its come again 5 seconds after start the engine. I can't understand which component is defective. Before a 4 months come with the same problem, but after SCN update in engine ECU and SCR module, then was everythink perfectm, but today still same. What can be the problem?
ML W166 250 CDI OM651
Attached File(s) Thumbnail(s)
The Best or Nothing!
12-12-2017, 06:43 AM
RE: W166 - AdBlue problem
What codes are in SCR module? You need to look in there.
12-12-2017, 07:02 AM
No fault code in SCR module
12-12-2017, 10:14 AM
NOX sensor can be the problem.
Did you perform all tests to that fault code?
Mercedes Comand/Audio antitheft codes all NTG
Mercedes Garmin Map Pilot Europe navi
Mercedes NTG5-6 Regio Software
12-12-2017, 10:20 AM
after I entered in fault code, then text me to check all adblue component, fuel system and nothing especially
12-12-2017, 01:25 PM
Dear Sir:
do you have re-calibrate the injector nozzle under SCR module?
i just suggest to remove injector to check whether it has some trace of injected adblue.
if not, you need check the pump, better to replace it.
from my view, this fault code conceive with supply of adblue.
please share your testing result.
12-12-2017, 01:30 PM
Addblue level sensor is a common problem in w166. I think there is problem. anyway we are waiting a response from you when you solve problem
Regards
12-12-2017, 09:18 PM (This post was last modified: 12-12-2017 09:48 PM by mbsupport.)
I remove the injector and clean it very carefully after that I make calibration...Second I make test on the adblue pump and there everythink is ok. Before this fault code I had another fault code which was for high value of NOx emissions. I check all actual values in SCR and Engine ECU and I did all tests, but I can't see nothing wrong
Attached File(s)
w166.rar
File Type: .rar
Downloaded: 19 times
adblue test pump.rar
File Type: .rar
Downloaded: 22 times
12-12-2017, 11:33 PM
did you just clear the fault code or resetted system via special proccess in CDI?
  W166 change cluster picture MrIgor 1 304 07-14-2018 04:40 AM
Last Post: gurgel
Mercedes Benz W166 gio777 9 611 07-08-2018 10:57 PM
Last Post: gio777
  W166 ML350 bluetec fault codes kznmerclady 3 432 07-05-2018 07:37 PM
Last Post: Slavjan75
Mercedes Benz Need Help AdBlue V-Class Roberto 1 171 06-25-2018 07:28 AM
Last Post: kmodel99
  about w166 ezs eis vediamo change SA linmax 8 2,504 06-17-2018 12:03 AM
Last Post: vincha7
