  • 2 Votes - 4.5 Average
W204 AIRBAG PROBLEM connect
08-12-2017, 12:11 PM
Mercedes Benz W204 AIRBAG PROBLEM connect
I have a question. I got a W204 for an airbag repair. SD sees everything except AIRBAG. I checked everything. I connected on the table. Power supply and CAN-L - CAN-H. There is no connection. I bought a second SRS module. The situation is identical. Can anyone help?
08-12-2017, 04:21 PM
RE: W204 AIRBAG PROBLEM connect
(08-12-2017 12:11 PM)wmarszak Wrote:  I have a question. I got a W204 for an airbag repair. SD sees everything except AIRBAG. I checked everything. I connected on the table. Power supply and CAN-L - CAN-H. There is no connection. I bought a second SRS module. The situation is identical. Can anyone help?
if second hand airbag got connection you need to reprogrammed to EZS
 Thanks given by: wmarszak
08-13-2017, 11:36 AM
CAN H/L wires in vehicle good? ECU has proper power/earth? If so and ECU is working should be able to communicate even if ECU is coded to different vehicle.
Until ECU and earth lug is correctly bolted down, the SRS ECU has no earth. If all seems good clean this earth point.
 Thanks given by: pesona
Mercedes Benz help me connect SD Connect 4 with lan cable kentrinite 13 834 07-15-2018 06:59 AM
Last Post: LORD
Saab Retofit headlights c class w204 2010 to 2014 Rayman123 3 340 07-14-2018 11:28 PM
Last Post: Rayman123
  Engine light W204 Impossible to diagnose mikeone 5 188 07-11-2018 11:19 PM
Last Post: Slavjan75
  MERCEDES W204 VGS 0009021807 CFF FILE pitstop0212 3 636 07-11-2018 09:24 AM
Last Post: MECA TRANSMISSION
  Open/Close window activation on W204 Domantas 4 306 07-10-2018 11:11 PM
Last Post: MBeO
