W208 need to generate EZS file
12-10-2017, 05:32 AM
1998 w208 EZS part number 2085450108
key stuck- no remote/no ignition
Two MCU 0d69J
"Outside" processor empty
"Inside" processor contents attached.
Is it possible to use inside dump for outside MCU? Maybe somenone can generate file from existing dump and NEC file for keys?
Attached File(s)
0d69j_inside_1.zip
File Type: .zip
Downloaded: 13 times
12-10-2017, 05:45 AM
RE: W208 need to generate EZS file
(12-10-2017 05:32 AM)ruklis Wrote:  1998 w208 EZS part number 2085450108
Two MCU 0d69J
Here for you dumps from same part number lock and generated keys from your EZS
Attached File(s)
0d69j_inside_1.rar
File Type: .rar
Downloaded: 10 times
 Thanks given by: tsimplas007 , ruklis
12-10-2017, 05:59 AM
thanks, will try.
I see CPU2 is "inside" CPU.
So I leave my content in it, write your CPU1 to "outside" and write keys- is that correct?
12-27-2017, 10:45 AM
(12-10-2017 05:59 AM)ruklis Wrote:  thanks, will try.
Did you solve the problem?
Regards
  M113 ME28 W208 4.3 -> 5.0 Engine Upgrade Flash question? posk69 2 166 07-01-2018 09:32 AM
Last Post: posk69
  about w166 ezs eis vediamo change SA linmax 8 2,508 06-17-2018 12:03 AM
Last Post: vincha7
Mercedes Benz Good tools to correct mileage on W204 2012 EZS + Dash mikeone 25 2,682 06-08-2018 06:58 PM
Last Post: andro822
Mercedes Benz W208 CLK55AMG Instrument cluster dump poxers 0 202 06-06-2018 03:11 AM
Last Post: poxers
Mercedes Benz [Solved] Problem with EZS W211 stachu121 7 530 06-05-2018 09:23 PM
Last Post: stachu121
