  • 7 Votes - 3 Average
W215 S500 No turn on dashboard and doesnt start
11-19-2017, 03:15 PM
Hello.
I have a Benz S500 W215 about 2001 year in the Garage. In official service told to client that he need to change Keys, EIS, Sam, Ecu .....
The problem is that the key work ok and unlock the car, and move EIS until ignition position, Steering wheel check to correct position but dashboard doesnt turn on and car doesnt Start. Someone have similar problem to help me??? If key turn in EIS means that EIS is ok, right?? or can have problem in EIS???
Thanks for any help.
Regards.
11-19-2017, 06:00 PM
RE: W215 S500 No turn on dashboard and doesnt start
Possible it has blown large prefuse X4/10 in front right footwell. Need to remove carpet and plate then can access fusebox to check..
 Thanks given by: Rocinante , bawarek , cosmiko , JarsaR
11-19-2017, 06:01 PM
Mercedes Benz RE: W215 S500 No turn on dashboard and doesnt start
(11-19-2017 03:15 PM)cosmiko Wrote:  Hello.
Regards.
Try to check EIS, may be faulty
Drive Press the Thanks and + If I really Help You.Kolo
 Thanks given by: HestonDiag
11-20-2017, 08:56 AM
Or maybe ELV is faulty
Same story is on W204 W207 W212
Turn Key on to Ignition and car dont start ---> problem is ELV
11-20-2017, 09:25 AM
W220 does not have ELV. To meet regulatory requirements, the gear selector lever is locked by immobiliser instead of having steering wheel lock.
 Thanks given by: cosmiko , bersch8688 , JarsaR
11-20-2017, 09:37 AM
(11-20-2017 09:25 AM)HestonDiag Wrote:  W220 does not have ELV. To meet regulatory requirements, the gear selector lever is locked by immobiliser instead of having steering wheel lock.
yes, he s wright. W220 and W215 have no steering lock
EIS is faulty or big fuse. (post 2)
if you can turn the key, then +30 and -31 in the little connectror at the EIS are ok.
check if the big connector at the EIS has +30 and if there is then i think
EIS to clean or is defective
 Thanks given by: cosmiko , JarsaR
11-21-2017, 06:59 AM
How to check if EIS is ok or not??? I have 2 EIS to check it, i can read EIS with VVDI Prog, but what do i need to do later to check if it's ok or no??
I will check big fuse later well, because i already did it.
Thanks.
11-21-2017, 07:43 AM
When Donor EIS its the same with HW number and inside read EEPROM and write to Donor EIS and test this in Car ;-)
Mercedes Benz W215 Datafiles needed pmercury 3 449 05-22-2018 11:31 PM
Last Post: Jake5555
Mercedes Benz W211 problem with front left turn signal,software update ahmad560 6 362 05-20-2018 04:13 PM
Last Post: schou
  dashboard virgin w903 93c66 edik 2 268 05-07-2018 07:34 AM
Last Post: edik
  Mercedes W245 same than W169, DASHBOARD change, shows ------ gomarota 4 421 04-28-2018 02:14 AM
Last Post: stachu121
  C240 W203 - 2004 - Can't Turn Ignition BigK 11 873 04-10-2018 05:04 AM
Last Post: BigK
